Spark Plug Heat Range For Turbocharged Engine
CarMichael Angelo
9,254
234
Birmingham, al
Trying to decide on which plugs to start off with as far as heat range goes. Naturally, the plug number is nothing anybody here would be familiar with, so I'm just asking in general.
Do I start out w/ a standard heat range plug, or step it one colder for initial start up?
Try two ranges colder and .030-.035 plug gap for a start.
Do you have any plans to an alcohol/water injection system to reduce intake manifold temps and possible detonation? If and you haven't already purchased one, I have some ideas for a simple controller that uses input from the TPS sensor and input from an analog MAP sensor.
Reactions: 1 users
Two steps colder with a smaller gap is what I would do. Always start off conservative. Ultimately it depends on how much boost you plan on running and you'll get a better feel after reading the plugs after it runs for a while .
A meth inj system is probably looking more likely, I checked my Mallory pump, and it isn't rated to pump E85, so I'll have to fall back to a system like you are talking about.
I am interested in hearing your ideas, a simple system is about all I can muster now that I just spent 600.00 on an oil pump.
Man, that's hard to swallow when a HV pump can be had for under $50. I understand why you did it, but I bet it hurt.
Joe
Oh I found the plug, it's just not familiar to me. I'm used to Motorcraft/Autolite numbers on windsor engines. Now I gotta plug that has a number like a Motorcraft AGS 52/42/32C, Autolite 65/64, an NGK BPR5E.
I know that the Motorcraft 52 is gonna be considered stock, so I'll shoot for the 32C then.
Thanks guys.
