wells1989
i am not looking to do irs in the back but am working on coil overs in the front. i currently run 17x9 cobra rs with a 245 45 front tire. you can see it in the pics i previously posted (top of page).
There's clearance at the fender lip and if I used a bfh and a little tweaking it could probably drop a 1/4-3/8" more. It has about 1-1 1/4" drop at the moment over stock. Here's another picThe tire set up looks good. Could you go any lower without rubbing issues if you wanted?
Brazoria dirt...Got it washed yesterday, took this a few minutes ago. It's already dirty again.
Brazoria dirt...
Nah, it was this morning. Hit a bunch of residual puddles at lunch today and someone was watering the landscaping down one of the streets by the office, as if it needed MORE water.
we need moaaaarrrrLove the little brown truck!
I have it venting to atmosphere now because I have a stand alone, and I don't have a picture of how it was routed with the stock ecu. But I used a plastic 90 degree elbow with pipe threads from Home Depot (I think in the washer/dryer section) on the power pipe to keep the hose from kinking.Can you take a pic of your power pipe and the location of the bung on it? I would like to see how you have your bypass valve hose routed.. mine is kinked!
i have a plastic 90 also but my bung on my powr pipe is at the 330 / 4 o'clock postion so no matter what my 90 is facing down!I have it venting to atmosphere now because I have a stand alone, and I don't have a picture of how it was routed with the stock ecu. But I used a plastic 90 degree elbow with pipe threads from Home Depot (I think in the washer/dryer section) on the power pipe to keep the hose from kinking.
andersonThat's interesting, the bung on mine is at a 6 o'clock position. Which brand is yours?
