You will be good just pull back on the rad and make sure at its lowest point pulled back it won't touch . If it does tweak the mount closer to the car or use an old belt and cut a strip the size of the rubber bushing in the rad mount so no one can see it protruding but it takes up the space if that makes sense . The way mine is it will not move back anymore then the position it's in right now .ya mines an 8 rib....and the rad is as far back as it goes,from what i can tell thats how they are?.....i looked at your pic toolow91 and tried to make it the same.....thanks for pic by the way,i feel better now!
