No real substance,....just keeping the thing on page one.
Yesterday, and today (in between applying for jobs) I decided to cap the passenger side fender where the bumper meets. I also installed both seats. Not so much as an attempt to move forward ( Since they'll come back out) but more to get them off the floor, and out of my way.
The fender extension was way too unstable. It simply needed some reinforcement. I added the 1/2" wide piece of strap, and now the thing is rock solid. I finally can move this side to bodywork mode.
Months ago, I actually had the driver seat kinda mocked up, but nothing was permanent. Yesterday, I made it so that they were. But,...they sit at too steep an angle rearward for me, so I'm thinkin that I'll add a 1" riser to the rear to correct that. For today however,...they're mounted and out of my way.
I drug the hood out and dealt with the water on the down pipe issue. Both your mustang, and my fairmont share similar hood substructure. That frame with the holes all around is how I intend for the air in the engine compartment to find a way out through the Gila vents at the rear of the hood. Problem is,.....there are 3 big gi honkin holes immediately above the down pipe, directly below the passenger side G vent. I had to come up with a Gandalf solution
I simply plated the bottom of those holes.
Not quite as impressive a feat as the Ol Gandy,....but just as effective. (only I wont fall to my death when the big thing passes by anyway)
Now water is gonna pour down on the driver side where those holes are still open, but the only thing water will pour on there is the rear most part of the intake manifold. Again,....I dont really plan to get caught in the rain, but I do expect to have to drive on a hot summer day,...so holes in the back of the hood win over worrying about water getting on my pretty engine.
I said before that when you cut the holes that expose that substructure, you also expose metal that Ford never intended to see the light of day. Consequently, there is a significant amount of surface rust accumulated on that inside metal. Since there really isn't a way to deal with that short of acid dipping the entire hood (not gonna happen) the cheesy solution to stopping that rust from advancing is to use the commonly available rust reformer. A spray paint that converts the rust from an active state, to a dormant state. It changes what we all call rust into a much more sophisticated version known as black magnetite. AKA rust that has been castrated.
I sprayed the hell outta those slots.
And killing two birds with one stone,...you get to see a side profile of the Gila Nostrils.
**Sorry assed picture hosting glitches...
This concludes tonight's update, we now return you to your regularly scheduled web browsing.
