Thanks...glad i can help in some way...lolGood luck. I'm hoping to install a V3 within the next year, this thread has been helpful with my research.
Felpro 1133s.....mls...living life on the edge now...lolWhich head gaskets did you end up going with?
Sent from my Samsung Note 4 using Tapatalk
.041 yes....tuner said im fine,so i rolled with it.$65 a piece, wow, I just went broke thinking about them. What methods did you use getting your block clean enough for them to seal right?
I will....drove it around a bit with no boost but,so far everything is working flawlessly.....ill report back after the final dyno...Cool, keep us posted on progress from time to time with these new head gaskets.
Yup, vortech kit comes with all mounting hardware and brackets which actually relocate the alternator under the smog pump.
Mine bolted up,but with the delete pulley i had to bend the braket straight for it to work....Cool. I knew all that got relocated, but I was worried I was going to have to hunt down some hardware and that little bracket for the smog pump delete kit.
