1988 notchback problems
MarcMonteverde
66
S@c-ToWn
i have a 1988 notch 5 speed 302
there are two problems, the first being after the car is warmed up it doesnt like to start.. slow crank or no crank like a dead battery, tested my battery was good. replaced starter relay/positive cable to relay, ground side cable of battery and starter to relay cable
second problem ill be driving and the rpm's will cut like if the i turned off the ignition and than turn it right back on. if it kills the car say at idle its a no start afterwards.
i bought a band new msd pro distru. new plugs and i changed my coil from autozone like 2 years ago when it went out.
sidenote question if you have a 65mm bbk throttle body and you put a stock replacement throttle position sensor on it will it throw off the reading?? because for some reason i checked the TPS and it was pretty much broken(plastic part over the wheel) so i got a autozone replacement
well i went out this morning and started it drove down the block and came back and parked it. turned it off and its a slow start no crank, im waitting for my video to upload and show you guys.
do you think my coil is going out since ill drive and it just cuts out it
was from autozone cheap fix i know but im pretty lost at this point
new msd distru. with msd tfi
new pump and filter
new plugs
new intake gasket upper and lower
wires are like 3 years old but no signs or arching
what could kill the ignition just driving down the street
Let's see vid....but my guess for slow/no crank is loose/bad connection, or heat soaked starter.
As for cutting out....run the codes. Use that to see of it gives you a starting point for diagnostics. Don't just replace parts randomly just yet
changed ignition switch 2 weeks ago because i thought it was.
i couldnt upload my video to youtube for some reason
the head soaked starter would make sense to me. for the slow start
i let the car run at idle for about 25 mins than it died randomly no surge idle and die just plan out fall on its face and no start from the starter im guessing
any way to test my coil or TFI mod. im thinking the coil could be getting hot and wont induce voltage onces it hot so gives a no spark i hear my pump run everytime i prime the key and its about a week old but the distru is one year old.. making me think coil but im not sure how to test these parts.
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstuck and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
attachment.php
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Sluggish start after warm motor is most likely the starter as stated before, go over all your grounds and make sure they have clean and tight connections. As far as the cutting out I had a car that did that once, never did figure it out, it's aggravating for sure :mad:
yeah so i checked my grounds the only ones i have are.
1. from block to -negative battery post.
2. body to my header
and they look like big gauge amp wire, yeah the starter is forsure the slow start problem ,i got off work and went to start it, was slow start.. car had been sitting all day since 8am-6pm it started aftetr a couple trys.
but the cutting out is what im really after now. im going to take my volt meter and do the " no start diagnose someone posted in another topic
