5spd Won't Shift Into Gear!
Discussion in '94-95 Tech' started by Lazieal, Nov 14, 2009.
  1. Lazieal New Member
    Jun 17, 2005
    Message Count:
    So when driving home in my 95 GT, I had a weird feeling shift into 5th gear. When I got off the freeway and tried to shift into 1st at a red light... I couldn't put it in any gear. If felt like all the gears were blocked and the stick shift only had N.
    I had it towed to my house and have not been able to put it in gear when the engine is on. If the engine is off I have 1-5+R.
    My car has a stock t-5 w/ a Pro 5.O shifter.
    Any ideas on what causes this and how to fix it?:shrug:
  2. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    Did your clutch or clutch cable take a dump?
    I'd start with the clutch quadrant/pawl and cable. Is there a lot of freeplay in the cable before there's resistance?
  3. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,229
    68
    It's a clutch problem. Hopefully it's just a cable problem, but likely it isn't. Most likely you have a spring that has popped out of the clutch disk.
    Kurt
  4. 302GTS If you need herpes, I'm your man!
    Apr 20, 2009
    Message Count:
    582
    Had the same issue when my clutch cable became stretched out. I noticed it quickly, and was able to get it fixed before needing a tow home one day. Swapped for the full Steeda replacement kit, and have loved it ever since. The FWA is awesome!
  5. urban96 bubb rubb says:"woo woooooo"
    Sep 25, 2002
    Message Count:
    4,233
    66
    +1 on clutch cable, start with that
Share This Page
