95 Cobra issues.
Discussion in '94-95 Tech' started by toppdogg_1, Oct 26, 2009.
  1. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    Just recently my car started having problems. It won't accelerate past 2.5-3k RPM. In neutral it won't rev past 4k. MASSIVE power loss. It doesn't misfire when easy on the throttle but if i try to punch it (which is pointless anyways) i can feel it misfiring. Tested with a new coil no difference. Tested TPS voltage and it was fine. Have a new MAF (old one went bad about 6 months ago) Has a new cap/rotor. No CEL is on or flashing or has turned on. The rear cat on passenger side does have a dent in it from when backing down a driveway and it hit the curb. I'm thinking the honeycomb broke and the cat's clogged and causing excessive backpressure, but i'm not sure. any other ideas?
    The car does have a Ford RPM Extender modified for Cobras but i don't think it's that because with extender disconnected car won't start so i would figure same thing would happen if it went bad.
    Thanks
    Edit: Also when going uphill i can barely get past 30-40mph just cuz of the RPM issue and also the engine temp starts to rise pretty quickly (doesn't overheat) but defiantly hotter then it should be especially with how cold it is outside.
  2. fordtech28 Member
    May 12, 2006
    Message Count:
    306
    could be the cat might of collapsed if it was hit pretty hard
    when was the last time you did the spark plug change and what spark plugs did you use I had a similiar issue with my cobra that it would buck when going at slows speeds and would misfire
  3. Chythar Active Member
    Aug 26, 2004
    Message Count:
    1,850
    48
    +1 on a blocked cat.
    Almost sounds like the SPOUT connector is out or shorted out. If you check the timing, at idle, is it rock solid at one setting, or does it bounce around? With the SPOUT in, the computer will adjust the timing on the fly. If the SPOUT is missing or the wires are damaged, the computer will not advance timing and your timing will be rock solid at idle.
    I forgot to put the SPOUT back in once, and it felt like the engine had something holding it back. It also had to work really hard at accelerating. Something to check.
  4. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,671
    66
    Sounds a lot more serious than the SPOUT being out.
    Are you sure the RPM extender has nothing to do with it? Perhaps try to eliminate the cat from a possibility and then go back to running without the extender if its still acting up.
  5. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    Checked the SPOUT it's in properly. Tested cranking fuel pressure it's a 40PSI. Gonna change plugs tomorrow and pull the extender. If they still don't make a difference gonna drop the stock mid-pipe and give it an open manifold run down the block to see if it did the trick, if so i'll just hack out the cat, put in a straight tube until emissions and then i'll order a magnaflow 93339
  6. 95Cobra302 Founding Member
    Apr 9, 2002
    Message Count:
    352
    Could be the PIP in the dizzy went bad.
  7. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,794
    76
    Pull codes. The CEL need not be illuminated (or have even flashed) to have codes stored.
    If you have a vac gauge, hook it up. Hold the revs at 2500 RPM (very steady) and see if the reading drops within a minute. If it does, that indicates an exhaust restriction.
    Checking the timing is so easy, do it as suggested. Severely retarded locked timing would run like crap with no pull at higher revs, and horrible off-idle performance.
    Is there a cut-in point with the extender (I thought they did but I might be thinking of something else)? If so, does this happen at that threshold? If so, I'd look there sooner.
    Matt, please move this to Tech.
  8. nmcgrawj Advanced Member
    Sep 28, 2003
    Message Count:
    3,671
    66
    Not sure how safe it is to run a stock motor on stock manifolds....be careful doing that.
  9. COBRA90GT Moderator
    Sep 22, 2001
    Message Count:
    6,832
    86
    toppdogg_1 - Did you figure out what it was? :shrug:
  10. greengoblin95 New Member
    Sep 30, 2009
    Message Count:
    94
    im willing to say that or the pickup coil. have you tested your tps? but if you are overheating under load as you are saying it could be clogged in your exhaust, but impropper timing can make your engine heat up as well.
  11. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    still working on it. Pulled the extender out just to make sure that wasn't it because i found out that it extender cut in rpm is 2500 and still same problem. I've checked the TPS voltage and it is linear with no issues. Borrowed a better jack from a friend so i'm gonna disconnect manifold before cats to see if it clears up. In Neutral the car won't rev past 3k.
    I've had my PIP go bad before and it didn't act like this, there would be starting issues, stalling, driving problems. The car starts fine everytime and doesn't stall. Instead of replacing PIP i swapped in a MSD dizzy (this was about 2 years ago).
    I did vacuum test also and the moment i let off throttle vacuum went back to where it should be almost immediately which is weird because if exhaust is clogged shouldn't it be slow but still gonna disconnect at manfiold.
    Also hooked up fuel pressure gauge. Had 40PSI while cranking. So doubt it fuel pump or clogged filter even though i'm going to change out filter also just incase
    It would be strange for the timing to be suddenly out of whack just because it never had a problem with it before and i haven't done anything that would affect timing, never played with the SPOUT, distributor is clamped down, tried to rotate it just to make sure and it didn't move.
    Is there a possibility it's the MAF? I swapped it out about 6months ago because it went bad (lean codes both banks) but it never gave me issues like this. Just and random CEL would turn on for about 10-20sec then turn off due to O2 sensors at max fuel compensation allowed.
  12. fordtech28 Member
    May 12, 2006
    Message Count:
    306
    Unplug the MAF to see if it changes it goes in to a fail safe mode or whatever its called if it revs fine you found your problem
  13. turbogt Member
    May 1, 2003
    Message Count:
    658
    18
    +1 for MAF
  14. StangGT1995 have car, will race....wait, it doesn't run
    Oct 23, 2004
    Message Count:
    5,294
    88
    +2 for MAF. Sounds identical to the problems I had when my factory MAF went bad.
  15. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    Unplugged MAF and reved it, no difference still wouldn't rev past 3-3.5k. Checked timing it was at 12degree. Time to unhook manifold from stock mid-pipe and give it a quick rip down the block
  16. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    cat was toast. put a 1inch wide 2 inch long rectangular cutout before 2nd cat on passenger side and problem's fixed, now to order new midpipe since confirmed problem
  17. diponyou50 New Member
    Apr 22, 2005
    Message Count:
    89
    awesome
    best feeling in the world!:D:nice:
  18. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    Planning on getting either the Pypes XFM-30 or Magnaflow 93339 catted mid-pipes. Both about $350ish (give or take $20) Any input on either one? The Pypes system seems nice since can pull out cats in 15-20min it seems like.
  19. Slapyo Administrator
    Feb 9, 2003
    Message Count:
    2,097
    46
    Unfortunately I don't think the 93339 is produced anymore. It's no longer in our list of products that we get from Magnaflow, they only have the 93333 which is the x-pipe.
  20. toppdogg_1 Founding Member
    Nov 28, 2001
    Message Count:
    89
    I noticed that also, that it's not on magnaflows website. But when I search google for "magnaflow 93339" and click on shopping it looks like it's still available from jegs, summit, i called autozone gave them them the part number and it looks like they can order it also :shrug:
Share This Page
