ABS ring problem
Discussion in '1994 - 1995 Specific Tech' started by 50mustang, Apr 14, 2013.
  1. Does anybody know what will happen if I installed new axles without an abs ring? I know its not as safe but i just want to know if it will still brake properly and not lock up my brakes for no reason. Thanks for any help
  2. ABS light I assume.
  3. As soon as the ABS light comes on you still have normal braking just no ABS operation.As soon as the problem is fixed the light will go out and you'll have ABS again.How hard will it be to have the rings added to your axles ? Are the axles drilled for ABS rings ?
