Aftermarket Bumper Problems
savegoodautonfg
1,085
I got a new aftermarket GT Bumper last christmas and put it on and every since then it wasnt on right so i just finished taking it back off.
1.) The Header Panel (http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-8284A 1&comp=LRS)
What is this made out of?
2.) I need to bond/glue/stick together the urethane bumper and this header panel. what stuff should i buy to do that?
3.) The studs that go into the header panel, they got like stripped out and the holes are a little too big now. can i use the same stuff im using to bond the bumper and header panel to put on the studs and then screw them in the header panel?
Thanks in advance.
copied from MSTANG
Automotive Aftermarket
Truck Line EZ Sand Flexible Parts Repair
08276, 400 mL, 6 per case
Two-part epoxy used to repair most plastic parts, including bumper covers, and other plastic body panels (not for use on SMC/fiberglass). Use 3M™ Polyolefin Primer 05907 for system II plastics. 10 minute work time, 30 minute sand time, 4 hour cure time
Buyer's Part Number : 08276
GTIN(UPC/EAN) : 0 00 51135 08276 8
3M Id : 60-9800-3708-3
ADDITIONAL INFORMATION
Automatic mixing. Designed to be used as a filler and adhesive. Epoxy based for easy sanding. Formulated for excellent feather edge.Flexible through a wide range of temperatures.
CHARACTERISTICS
Clamp Time
1 Hour
Color
Gray
Cure or Dry Time
4 Hour
Work Time
10 Minute
3M 1995-2001
had asked that question earlier and didnt get the answer I was looking for.
But I found it today at a Auto Body Shop supply store.
Its called REMOV ALL Stripper, it comes in a spray can and it states that it works on all of the normal metal surfaces and also works on TPO Bumpers, Rubber Seals. I have not used it yet but I thought I would find my old Thread and add this info to it. In looking for my thread I found yours.
