Any differences between new edge GT's?
Discussion in 'SN95 4.6 Talk' started by WhiteDevil, Jun 10, 2008.
  1. WhiteDevil New Member
    Feb 5, 2003
    Message Count:
    2,720
    Well im moving on from my old stang and looking to get a 00-03 GT. I am just wondering if there are any advantages or disadvantages to any years. Or any major differences between the years. School me guys, Thanks!
  2. T-Sho New Member
    Aug 1, 2006
    Message Count:
    64
    I believe the 00-03 GTs are basically the same performance wise with only a few cosmetic changes :shrug:
  3. WhiteDevil New Member
    Feb 5, 2003
    Message Count:
    2,720
    I know performance wise they are the same. Im just wondering what cosmetic changes or interior changes there were. Also i know there is a switch from T-45 to T-3650 or something like that at some point as well. But im not sure which is better and when the change happened.
  4. GT-03 New Member
    Dec 12, 2003
    Message Count:
    631
    The '03 and '04 have much thicker A-pillars. Its for better rollover safety.
    The console design changed somewhere in SN95's, at least a few times.
  5. Nightstick New Member
    Jul 2, 2007
    Message Count:
    69
    01' was first year for Bullitt rims, taller hood scoop, and factory tinted headlights.
    I think I read somewhere the 01's harmonic balancer has most mass of all previous years of 96' up. Mass air sensor wiring is slightly different on the 02-04s.
    Mid year of 01, the 3650 5-speed was swapped in(supposedly more robust than the T-45). Rear defogger button is moved down to console instead of dash on 01'.
  6. WhiteDevil New Member
    Feb 5, 2003
    Message Count:
    2,720
    so i definitely like the blacked out head lights. SO ill have to focus on an 01+ for that. See this is the info that helps me make a choice! Keep it comin guys!
  7. Wolvrin704 New Member
    Apr 18, 2007
    Message Count:
    131
    Also I may be wrong but I believe for the 03 and 04 they went to the adjustable tilting head rests. Mine is an 03 and I have it so I'm unsure about previous years. I like the look of my 03 so much that I really don't plan on many cosmetic changes. DD bullits on back and another Mach 1 chin spoiler are about all I'll be doing.
  8. 89lxsport50 Member
    Feb 25, 2003
    Message Count:
    545
    02 was the first year with the aluminum crossover on the intake instead of plastic.
  9. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,691
    48
    2001 and 1/2 technically...:D
    99-00 4.6's are Windsor motors, 01-04 are Romeo. A few small differences between the engines, but none that will affect the power a car from either year(s) would make.
    00-mid 2001 still have the T-45. Not as "strong" but ill be damned if it isnt 3x more reliable than the 3650's are. Mine shifts smooth as butter with almost 130k abusive miles on it.
    I beleive (correct me if im wrong please) either 2001 or 2002 got larger fuel injectors, 99-00/01 were 19lbs/hr and the newer ones are 21lbs/hr I beleive.
  10. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,550
    78
    The 4-way tilting headrests were available on 03's and '04's that got the Interior Upgrade Package. If you didn't get the package, you still got the normal small headrests.
    02-03's also have an overhead storage net that was deleted in '04.
    I think the interior of the 01+ is nicer. You get the 6-disk in-dash cd changer and the damn defrost button isn't under the headlight switch. :nonono:
    Basically...buy the newest mustang with the least amount of miles you can afford. It's a buyer's market out there. Beleive me...i know. I've gone from $13K to $10K for my '03 GT and still can't sell it.
  11. Mach1Run New Member
    Jun 25, 2004
    Message Count:
    417
    Mid year 2001
  12. scupking Active Member
    Sep 19, 2005
    Message Count:
    1,198
    36
    Basicly 2001-2004 look the same in and out, the 99-00s had the 98 interior, no hood scope, different wing and standard white head lights (01-04 are blacked out).
  13. Nightstick New Member
    Jul 2, 2007
    Message Count:
    69
    For 2002 the Mach 1000 audio system with MP3 capability was available with 2 subs and 4 amps in the trunk....
  14. 00stangv6lr New Member
    Sep 26, 2006
    Message Count:
    61
    I was told from a ford service tech that the 03-04 models had more threads in the head to help with spark blug blowouts, someone please correct me if this is wrong though.
  15. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,550
    78
    I think they changed the spark plug and not the head.
    I've seen plenty of 03/04's still spit the plugs
  16. Mach1Run New Member
    Jun 25, 2004
    Message Count:
    417
    there is a difference in heads, at least on the machs. some heads take 4 turns to seat the plug. these were the ones prone to blowout. if it has the revised heads its should take about 8.
  17. T-Sho New Member
    Aug 1, 2006
    Message Count:
    64
    Yeah I know. Nobody wants a gas guzzling V8 with gas prices the way they are :( But it works for me because I'm planning on getting something new within the next year or so :D.
  18. 2000fordstanggt Member
    Sep 6, 2005
    Message Count:
    415
    i was at the relvealing of the new lincoln mks at the dealer monday and was looking at the window sticker of the mkx x-over/suv (whatever it is) and the fuel economy rating was something like 17 city and 24 highway, with a 3.5 liter!
    im getting way better than that, must be pretty heavy i guess.
  19. Mustang92 SN's #1 1%er
    Jun 6, 2001
    Message Count:
    6,471
    76
    They are all 19lbs injectors, orange or pink they are the same.
    The 04's did get a revised head with more thread on the spark plugs.
    Depending on what you are looking to spend you can find some great deals on Mach 1's also.
    The funny thing is so many consider a V8 Mustang to be a gas guzzler yet mine gets consisently 21-22 MPG driving back and forth to work. That's close to double what my diesel truck was getting and it cut my monthly fuel costs down 60%.
    Bill
  20. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,550
    78
    If you toss it in 5th the Mustang actually gets decent fuel economy. My window sticker says 25MPG highway i beleive.
    A lot of the V6's i'm looking at for a new car are rated at about the same.
Share This Page
