Standard Claims List For Model Year 1999
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 13 6X04 010904 F85Z 17682 FAA M05 42 7673
AWS Claim Key: 9001837 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02771 - * Name: JACK DEMMER FORD, INC. Ph: 734-7212600 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2000 Doc #:228652D
Cust Comments: PASS SIDE MIRROR LOOSE ,FOLDS IN IN TO EASY
Tech Comments: 7673 42 PASS. SIDE POWER MIRROR NOT OPERATING PROPERLY FOLDS TO EASY AND RATTLES NECESSARY TO REPLACE PASS. SIDE POWER MIRROR
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 13 6L06 011201 * 1506072 * N33 07 7673
AWS Claim Key: 9001838 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02771 - * Name: JACK DEMMER FORD, INC. Ph: 734-7212600 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:11-MAY-2000 Doc #:228652E
Cust Comments: DASH RATTLE ON RIGHT SIDE
Tech Comments: 7673 07 TEST DRIVE TRUCK VERIFIED RATTLE FROM RIGHT SIDE DASH NECESSARY TO ADJUST GLOVEBOX STRIKER INWARD FOR PROPER FIT, TEST DRIVE O.K
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 28 2B02 03XXXX 1L2Z 12029 AA E29 46 14327
AWS Claim Key: 17280274 Trx Code: S07 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 02771 - * Name: JACK DEMMER FORD, INC. Ph: 734-7212600 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2001 Doc #:255392A
Cust Comments: CHECK ENGINE LIGHT ON ,LACKS POWER ON ACCEL
Tech Comments: 14330 46 EEC TEST YKOEO YKOEC CODE P0304 NGS MONITOR PINPOINT TEST COMPRESSION TEST AT 148 PSI DIAG AND REPLACE #4 COIL AND SPARK PLUG SHORTED RETEST CODE P1000 ROADTEST OK
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 36 1A04 * * * * * * 26034
AWS Claim Key: 20634008 Trx Code: 01B81 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 02312 - * Name: MATHEWS NEWARK FORD LINCOLN MERCURY Ph: 740-5222181 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-APR-2002 Doc #:149698A
Cust Comments: 01B81 INTERCOOLER FIELD SERVICE ACTION
Tech Comments: 26034 REMOVED AND REPLACED INTERCOOLER PER RECALL.
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 48 5A06 0502XX F75Z 4026 AA N51 42 31767
AWS Claim Key: 22220255 Trx Code: 0878D Labor Hrs: 3.6
Dlr Cd-Sub Cd: 00987 - * Name: CIENER-WOODS FORD Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2003 Doc #:09997551
Cust Comments: CK NOISE IN REAR END
Tech Comments: NOISE IN REAR END.DIFF BAD DIFFERENTIAL CARRIER ASSEMBLY IN CHASSIS INTEGRAL CARRIE
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 50 1A02 030102 3U7Z 6051 AA L65 D8 34802
AWS Claim Key: 22387921 Trx Code: 0878D Labor Hrs: 8.6
Dlr Cd-Sub Cd: 00987 - * Name: CIENER-WOODS FORD Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2003 Doc #:00290351
Cust Comments: CK FOR POSS OIL LEAK REAR OF ENGINE
Tech Comments: RT HEADGASKET IS LEAKING ENGINE ASSEMBLY REMOVE AND INSTALL
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 50 7K11 130101 XL3Z 10849 EA L29 42 34802
AWS Claim Key: 22387922 Trx Code: P05 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00987 - * Name: CIENER-WOODS FORD Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:28-MAY-2003 Doc #:00290352
Cust Comments: INST PANEL LIGHTS IN OP
Tech Comments: INSTRUMENT CLUSTER IS BAD BODY CHASSIS ELECTRIAL (BCE) TEST
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 51 7K11 130101 XL3Z 10849 EA T90 42 34882
AWS Claim Key: 22405785 Trx Code: P08 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00987 - * Name: CIENER-WOODS FORD Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2003 Doc #:00340051
Cust Comments: CK INSTRUMENT CLUSTER LOOKS BUBBLED WHEN LIGHTS ARE ON
Tech Comments: INST CLUSTER IS BAD INSTRUMENT CLUSTER REMOVE AND INSTALL OR REPLACE
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 51 1D02 03XXXX XL3Z 9461 AA D21 D8 34882
AWS Claim Key: 22405786 Trx Code: SPW Labor Hrs: 2.7
Dlr Cd-Sub Cd: 00987 - * Name: CIENER-WOODS FORD Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2003 Doc #:00340052
Cust Comments: CK NOT MUCH POWER WHEN DRIVING
Tech Comments: LOWER INTERCOOLER GASKET IS BAD EEC SELF TEST TEST
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 51 2H02 030001 XL3Z 6F066 AA D21 42 34882
AWS Claim Key: 22405787 Trx Code: 0878D Labor Hrs: 0
Dlr Cd-Sub Cd: 00987 - * Name: CIENER-WOODS FORD Ph: 336-9963700 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2003 Doc #:00340053
Cust Comments: CK FOR LOSS OF POWER
Tech Comments: SUPERCHARGER IS BAD REPLACED SUPERCHARGER PER HOTLINE. NO LABOR. HAD OFF TO REPLACE
2FTZF0734XCA72439 T/F5 F T/BB T/AM T/B A4 T/D7 T/WP 15-APR-1999 27-APR-1999 148016 USA 70 3A08 070100 1C3Z 7902 BARM P59 42 55672
AWS Claim Key: 23528986 Trx Code: 0878D Labor Hrs: 12.7
Dlr Cd-Sub Cd: 09844 - * Name: CAPITAL FORD LINCOLN MERCURY OF WILMINGTON Ph: 910-7994060 St:NC Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2005 Doc #:01274151
Cust Comments: WHEN VEHICLE IS COLD SEEMS TO SHIFT OK, ONCE GETS WARM ENGINE RPMS SEEMS TO GO HIGHER, TRANS WILL NOT GO INTO FOURTH GEAR AT ALL, SOMETIMES REVERSE
Tech Comments: FAULTY TRANSMISSION AUTOMATIC TRANSMISSION ASSEMBLY REMOVE AND INSTALL OR REPLACE
