Can anybody tell me what belt i need. I have A/C eliminater kit and it moved the PS pump up to where the A/C was. Summit told me what belt to use, but its not right. I have no smog pump either. The belt is 84.5 inches and its to long
75 fit but not tight. Got a 74.5 going to try it tonight. Stock pulleys. Love those pics mikestang63
Check the appoximate length required using a piece of string along one of the routings shown in the diagram below:
If you use the string method, then remember to "by-pass" the tensioner pulley to get your length.
So I've been having a belt issue. My setup stretches my belt, and I need a new one every ~3 months. Mine is set up like the smog pump bypass, but the AC is deleted, the powersteering was not relocated, and there is a tensioner bar, no belt tensioner.
So it is alternator to PS, to crank and water pump....It was this way when I bought the car, I just replaced the brackets it had, since they were old and broken. It has the MARCH A/C delete and MARCH alternator bracket with tensioner bar.
