Well, if I remember right, and you probably already know, trac control cuts the fuel. this could lead to a lean condition that is BAD for boost. Detonation...holes in those marvelous hyperpathetic pistons...broken rings...an unwanted "PVC" valve...
With motorcycles, if they are running lean, they will sneeze and pop through the
carb. Of course XX psi of boost would probably prevent that...
Do a search for traction control delete and get the web address for a little box that will not reset the control to "on" when you start the engine. Cost like 50 bucks. Get it and get it now.
Probably didn't hurt the engine. Loss of power, ugly noises, black smoke, loss of compression and a Giant Mushroom Cloud on the other hand...
Hope everything is ok and I hope you won!
