Hawk semi metallic? I'd like to stop well but not dust a lot on my shiny wheels. One of life's compromises I guess. Hawk ceramics worth 80 some odd dolla a pair or just like any ole parts house ceramic?Depends on how well you want it to stop. I like Hawk pads, but they do dust a lot on a floating caliper.
Kurt
Thanks manI like the smoothness of Ceramics. They don't eat through your rotors as much either. I think they dust a little more than Semi-metallics, but the dust is less corrosive on the wheels. The best way to keep the dust down is to make sure the wheel beatings are good so the rotor doesn't walk in and out, the rotor isn't warped, and the caliper pins are well lubed.
Kurt
I'm gonna be doing brakes on both a fox and sn. Gonna keep stock rotors and calipers on both.I'm running OEM Ford pads, but I also have sn95 brakes.
Low dust, low noise. Stopping power isn't a concern when running 13" brakes on a fox.
I bought the same package from Steeda way back in the day. Works excellent. You have to file the sleeves to make them fit on the pins, but it doesn't take much time at all. Totally agree, that is an excellent upgrade.
Kurt
That causes them to bind. You are supposed to file them until they slide easily. The whole point of putting the SS sleeves in is to have the caliper pin float freely with no wiggle. If you don't file them, you are going to get a lot of brake dust.
Kurt
Have to get new wheels n tires
When I did it, one of the 4 pins slid right in, the other 3 needed filing. On the other car I did, all 4 needed filing. Takes a matter of minutes. It's not that big of a deal.
Kurt
