I've got a summit racing electric pump and spring type regulator. My fuel pressure won't stay consistent. right now I've got the line from the pump running into the bottom of the regulator, and a line running into my carb from one of the side ports on the regulator. The other side outlet is plugged. My pressure will stay around 7 pounds but occasionally spikes to about 25 psi. then gas usually ends up spilling out of the top of my carb and all over my engine. So as you can probably see I have a problem. Do I have a problem with how my regulators set up? Do I need to run a return line?
