Hello. My '95 Cobra SVT seems to be having cooling issues. The heater core is very hot but the radiator is not. I replaced the thermostat and replaced the coolant. Thermostat is 180 degrees. I tested the stat in a pan of hot water for functionality but I don't know the exact temperature that it opened.
I ran the engine with the radiator cap off and the coolant does seem to rise in the radiator but it doesn't seem to be moving around very much if at all.
So I took the thermostat back off again and it looks like I might have put it on slightly askew. It's a vertical mount (as you probably know) and I'm going to try to use some sealant to hold it in place. I had a heck of a time trying to make it stay put until I could re-attach the elbow housing.
The water pump seems to be squealing a bit until it's warmed up. But the pump doesn't leak. The squealing is a sign of it failing? I just purchased an infrared thermometer to do some testing with.
Any suggestions for how to tell if my water pump is producing sufficient output and/or if I have an air bubble stuck somewhere?
Thanks in advance!
Thanks in advance!
