ok, i finally took the car out and beat it up a little bit. the car literally feels like it has about 200hp. the timing is at 10*, fuel pressure is at 36psi vacuum on, and i have been over everything twice to make sure that all is correct. it has to be a tuning issue. for those that arent aware of my situation, i blew the rings in the stock 302 in january of 06 and did a full change over. the mod list is:
anyway, everything is basically new from the upper intake to the rearend. at this point, i just want the car done with as little addition hassle as possible. my question is, if i contact a reputable tuner and give him a full list of mods, what are the odds he can burn me a chip that will bring out the beast in the car. i know without being on a dyno, perfection is impossible, but that isnt my concern at this point. if it can be done, can anyone recommend a good place to get this done? thanks in advance.....
motor:
CHP 331 Stroker Motor (8.8:1 Compression), Vortech V1 S-Trim Supercharger, Eagle 4340 Forged Crankshaft, Probe Industries Lightweight I-Beam Rods, Probe Industries SRS Pistons, Holley Systemax Intake Manifold (Inlet Ported To 75mm), AFR 185 61cc Cylinder Heads, Cometic MLS Head Gaskets, Comp Cams Camshaft - FW 284H-R14 (.533/.544 114LSA), Probe Industries Main Girdle, BBK 75mm Throttle Body, Edelbrock Throttle Body Inlet Adapter (Port Matched To Throttle Body), Pro-M 77mm MAF, Probe Industries 1.6 Lightweight Billet Stud Mount Rockers, Probe Industries Dominator Timing Chain, Romac Ultra Light Harmonic Balancer, Fidanza Aluminum Flywheel, AFM Power Pipe, AFM Chrome Valve Covers, Kirban Adjustable FPR, MSD 6AL Ignition, MSD Blaster TFI Coil, MSD 8.5mm Spark Plug Wires, MSD Cap & Rotor, FRPP 42lb/hr. Injectors, MAC 1-5/8" Ceramic Coated Longtube Headers, MAC 2.5" Prochamber, Flowmaster American Thunder Catback Exhaust, Canton 7qt. Oil Pan, FelPro Gaskets, ARP 12pt Intake Bolts, ARP Head Studs, Energy Suspension Polyurethane Motor Mounts, ASP Smog Pump Idler Pulley, Cardone High Torque Starter, Walbro 255lph Intank Fuel Pump, Vortech T-Rex 155lph Inline Fuel Pump, Stage 8 Locking Header Bolts, Pro-M o2 Sensor Extenders, Fluidyne Aluminum Radiator, 180° Thermostat, K&N Filter, PLX M-300 Wideband o2 Sensor, SCE Copper Exhaust Gaskets, Removed Accessories (A/C, Power Steering, Smog Pump, & EGR), HP Stainless Supercharger Oil Feed Line, TwEECer R/T
drivetrain:
AODE - Manual Transmission Swap, Tremec TKO600, Steeda Tri-Ax, Pro Motion Kustom Clutch (FRPP Blueprinted HD Pressure Plate/McLeod Disc), Tremec Bellhousing, D&D C62 Super HD Clutch Fork, Energy Suspension Polyurethane Transmission Mount, FRPP Aluminum Driveshaft, Fiore Performance Clutch Quadrant, Fiore Performance Firewall Adjuster, Steeda Adjustable Clutch Cable, Steeda Driveshaft Spacer, 3.27 Ring & Pinion
