Door lock issue?
Discussion in 'Fox 5.0 Mustang Tech' started by stangz4life, Nov 4, 2009.
  1. stangz4life Founding Member
    Apr 8, 2002
    Message Count:
    155
    tampa,fl
    :mad:Ok i am trying to help my mom out right now. Her door locks on her 92 2.3 (yes i know this is 5.0 area but door locks are the same)have not been able to lock or unlock useing the key from the outside, it was like when you put the key in it would turn a little and then it would be hard as hell and would stop and not let you go either way like something was jamed up. Anyways the power locks both finaly stopped working alltogether now. I figured the reason the keys wouldnt work was because of the actuators were stuck. I just changed out the driverside accuator tonight and it will lock and unlock with the power lock button but when i try it with the key it is still the same way as before i changed it...what can be the problem both driver and passenger side are like this. Kinda defeats the purpose of changing them for her if she still cannot lock the door.(if i cant figure it out i guess i can always install keyless entry but i want to find the original problem) Any sujestions? Yes i have read thru the posts and i cant find anything on this all say its the actuator.... Thanks in advance !!!
  2. k4mjk New Member
    Sep 5, 2009
    Message Count:
    49
    North East Georgia
    pull the locks out and see if they turn (there is a tab inside the door jamb) if they do then the lock mechanism is stuck i would use WD40 on it and try to break it free years of grime and lack of lubrication will do that
    Sponsored Ad
  3. stangz4life Founding Member
    Apr 8, 2002
    Message Count:
    155
    tampa,fl
    Here is a update..i thought the same thing as you did ,but i just took off the passenger side actuator and tried the key and all works fine once the acctuator is off there. So i installed the new one and once i did that it went back to the same thing where the key will not turn. I just dont get it ...it has a new accuator that works fine but now it seams to hard to turn the key like the accuator is to hard to move up and down with the key. Just a note the ones i installed are not factory ford they are form late model restoration i just bought the kit. Man its pissing me off. Brand new accuators and she still wont be able to lock the doors..unless she wants to open the hatch and crawl to the front..........any more ideas????
  4. Prime Lord Crappy Default Title
    Sep 19, 2000
    Message Count:
    1,986
    36
    Communist-wealth of VA
    I got that same kit from 50Resto...the actuators are STIFF as crap and take a while to break in before they will be nice a easy. I thought I was going to break the key off the first time I tried to use it...after about a month of locking/unlocking they loosened up significantly.
  5. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,891
    31
    98
    Dublin GA
    Don't waste your money on door lock actuators from some expensive Mustang specialty store. There is a better way...
    Follow this link to fix your door lock actuator problems: Mustang Door Lock Actuator Retrofit
    Stuck with door lock actuators that don't work and don't want to pay the $50+ for a new one? Tried the junkyard ones and found that they last six months and freeze up?
    A new actuator for less than $5. Fix one side for $18, do both sides for only $25. I don't sell parts, I don’t make any money off of the upgrade, I just tell you how to do it cheaply and easily.
    Here’s a picture of the new actuator installed:
    [IMG]
  6. stangz4life Founding Member
    Apr 8, 2002
    Message Count:
    155
    tampa,fl
    So this is the norm for new accuators you are saying? Dam they are stiff as all hell !!!! Yes jrichker i saw your posting of that fix in just about every post involving door actuators ...looks all good but i am just the buy the correct part and replace kinda guy. The kit isnt to pricey really. But thanks for the link though. I am sure others have found it really usefull. I just hope these things loosen up a bit.
  7. k4mjk New Member
    Sep 5, 2009
    Message Count:
    49
    North East Georgia
    squirt some wd40 on the shaft while it is extended and work it up and down it should loosen up :nice:
    :eek:
  8. stangz4life Founding Member
    Apr 8, 2002
    Message Count:
    155
    tampa,fl
    I tried that but didnt seam to work i thought maybe the was a issue with something binding but if that was the case then the key shouldnt work with the acctuator disonected as everything is the same with or without the accuator installed.
  9. glowstang93 Member
    Feb 9, 2003
    Message Count:
    822
    Illinois
    I thought the same thing, easier to just replace with the correct part. The fix is not that hard, just takes about 30 minutes at a good hardware store to get the parts and its easy as pie. They work so much better than the correct part.
Share This Page
