I am having a problem with a ground somewhere on the car.
First thing it did about 3 months ago was when I was driving my water temp and oil pressure gauges shot all the way up, along with my Autometer water temp gauge.
Then, about a month after that it wouldn't start after I stopped at a gas station. We thought it was the starter, had it towed, had the Ford dealership replace the starter (which they said was bad) and it turns out it wasn't. So, I am thinking it was this ground problem all along.
Now, the other day it did the same thing it did when we thought the starter went out. I just randomly remembered to try and ground it (connected jumper cables from negative battery cable to intake bolt) and it fired right up.
Gauges were maxing out again but I drove it anyways.
Next day it is fine again.
What on earth could this be? Should I just add another ground from the intake to somewhere?
Thanks,
Kevin
Thanks,
Kevin
