All right, about 6 weeks ago I started to have an intermitent fuel pump problem. Sometimes it would continue to run after I shut the car off, a couple of times the pump was off when I shut the car down & when I came back a short time later the pump was running. This happened more than once. Most of the time it worked like it should. I ended up changing the FP relay and until the other day it has been fine. I had to drive the car in the rain and about 2 miles from my home the car started cutting out and drive poorly anything past a light pedal. So I pull into the garage and I get out of the car and I hear the pump running again. It was getting late so I just pulled the the negative terminal for the time being. Well I go out this morning to track the problem down, put the cable back on the battery and I dont hear the pump running. So I start it up and go for a drive. The car ran great, drove smooth at part throttle and I had 3rd gear to 6000 rpms heavy throttle and it ran fricking great. So now Im like what do I do now. I stopped at Wal-mart on the way home. The FP was not running when I shut the car off. When I came back out the pump was running again. When I put the key in the ignition and turned it to full forward I heard the normal noises that happen when the pump primes, after that the pump stopped running and the car started right up and ran fine. I got home with no problems and pulled into the garage, when I turned the car off the FP was still running and then it stopped for a few seconds. When it stopped I heard a slight chattering coming from the FP relay, Wen I grabbed the relay it was very hot, and the FP started running again, but the chattering in the relay was gone. I turned the car on and off a few more times and both symptoms happened again but never at the same time. I dont see any wiring issues that are plainly visible, but I was hoping someone might be able to give me a step by step methodology to tracking this down. Worst case senario I drop the tank and check the wires from front to back, but I was really hoping for a simpler solution. Thanks in advance
This sucks because I was ready for a tune until this happened!
