Why would you give up a Trick Flow intake and put in a stock portedBlackVert said:ok you guys have convinced me.
42#ers and a 255 lpg pump it is.
i'm also going to get a ported stock lower from tmoss and sell my tfs street heat intake.
the kb won't fit on a trick flow lower. see this:94GTLaserRC said:Why would you give up a Trick Flow intake and put in a stock ported
RC
I forgot.BlackVert said:the kb won't fit on a trick flow lower. see this:
http://forums.stangnet.com/showthread.php?t=576723
The NJ Exile said:You might look in to the Holley Lower... I will fit. I ran my 1.5 on it untill I upgraded to the 2.2 and GT-40 Lower ( so I could runn the Flowzilla intake)
VibrantRedGT said:Or have the stock lower ported to the hilt.
BLACK VERT said:I'm also going to get a ported stock lower from tmoss and sell my tfs street heat intake.
Never say never my freind.....http://www.allenengine.com/01must1.html94GTLaserRC said:He's buying it used.
Again, as I said above....I dont believe you'll find any member on our boards with a power adder, 30's and NO FMU.
RC
HAHAHA...I NEVER say "NEVER"Gearbanger 101 said:Never say never my freind.....http://www.allenengine.com/01must1.html
KillerCanary said in this thread you have to put a spacer on the the pulley ... no big deal?94TURBO5 O said:Chris,
You should buy his lower System Max (the one I was using) and he also might have the Flowzilla for it with the bypass valve still sitting around.
ya i thought you used the cobra lower when you had it94TURBO5 O said:Chris,
Chris Curl said:From: Chris Curl
To: [email protected]
Sent: Tuesday, August 30, 2005 9:01 PM
Subject: what lowers will this fit?
a friend of mine is selling me his kenne bell supercharger that he just
got rebuilt (1.8L - really! it is not 1.5L or 2.2L, but 1.8L) for my
1995 mustang gt (5.0L pushrod). he says it fits his holley systemax
lower and also a stock lower intake.
will it fit my trick flow lower intake?
also, are 30# injectors correct for that blower at 8#s of boost?
- chris
[email protected] said:From: "James" <[email protected]> Add to Address Book
Subject: Re: what lowers will this fit?
Date: Thu, 1 Sep 2005 09:59:42 -0700
The discharge is for a standard intake. If the ports on the other lowers are the same then it would fit but I don't believe they are on the trick flow. I didn't even think they were the same on the Holley lower. If you have a stock lower end then the 30's are fine with your setup. Thank you, KB.
the bigger ones fit a gt40 lower intake.urban96 said:ya i thought you used the cobra lower when you had it
BlackVert said:the bigger ones fit a gt40 lower intake.
