Boostedpimp
Dirt-Old 20+Year Member
Previous owner states 327 RWHP and 290 TQ without a tune
7k rpms? Wouldn't the stock ECU rev limiter kick in? You could try to rev it that high but doubt you'd want to. You'd need a solid roller or shaft mount rocker type valve train for those rpms. If you dyno the car, the answer will be in the dyno graph for you.Thoughts on shift points for this car? I picked the car up last night - everything is fantastic.
Previous owner states that he always shifted at 4-5k but mentioned that he was told he could shift at ~7k with the motor?
Ditch the MAF and get a Stinger Pimp or MSPNP for stand alone tuning. A dyno tune is still helpful to a certain extent but you can tune it mostly yourself. Dyno tune typically helps with dialing in your timing in order to run the most you can SAFELY. The dyno will give you important indicators that your butt dyno will not. For fuel, drop the tank and upgrade your fuel pump along with properly sized injectors is the best way to go.Any other recommendations for some more power? Should I change the MAF?
