Why does my car not start sometimes and then if a few mintes fire up like nothing happened?
I go out to the car at lunch yesterday and it just cranks and cranks and cranks, but not a hint of trying to fire. I check fuel pressure, fine, I hear the pump running, good, I wiggle all the sensor connections I see, nothing loose, crank crank crank nothing. say a quick prayer and it fires right up and works fine the rest of the day.
This moring I go to start the car to go to work and it just cranks and cranks and cranks, not a hint of trying to fire. I hear the fuel pump. so I check for engine codes using hte check engine light and jumper in the eec test socket. I don't get anything I can decifer out of the check engine light. 133 133 and that's it.
so I put a spark plug on the coil ht lead and set it on the intake manifold and turn the car over and see all kinds of spark, so I re attach the coil and it fires right up.
What's going on? is it ignition, does the tif or coil do an intermittant problem?
This happened 2 other times this summer and once last year.
stock pump, stock ignition, 113000 miles 95 gts manual. only mods are an intake, tb and k&n.
Jim
Jim
