3116 Can someone verify this number and also is it a message or a bulletin?
Mustang - Cold engine light ticking/rattle noise:
Some 2001-2002 Mustang GT and Bullitt with the TR3650 Manual Trasmission may exhibit a light ticking/rattle noise while driving after a cold engine start. The noise will typically occur between 2200-3500 RPM under light throttle (1/8 to 1/4 open) while driving. The noise may last for a few minutes (depending on temperature). The condition is due to the combination of light load operation noted above and normal piston to cylinder bore clearance present in the cold engine. To service, verify condition & reprogram the PCM with the latest calibration available via the just-in-time process if your WDS communicates with Fordstar. Also obtain calibrations on the Ford Professional Technician Society (PTS) website - select WDS then PCM reprogramming and click instructions for downloading...
