First off....thanks to Bill Gear...it took a while since the drop shipper sent my wheels to MO instead of MD...but I got wheels today and ran right out and get those 275 40 17 BFG DR I bought mounted
First thing that struck me was the size of these tires compared to my 255 40 17 on the same size rim
Pre-mounting research led me to beleive that they would end up being about 10.5 inch wide when mounted on an 8 inch rim...well that turned out incorrect...must be differences in brands since I got that measurement from another brand (iirc). As you can see my BFG KDs are 10 inches bulge to bulge
And it turns out these DRs are......11 :horror:
So some of you may remember how I posted about having 11.5 inches of clearance on one side...and 10.5 on the other...well that hasn't changed...so I'm already off to a bad start.
Mounting up the tires onto the car I didn't run into too many problems. As you can see, I clear the leaf springs ok
Passenger side:
Driver side:
But then I run into a small problem...front of the wheel well on passnger side there is light contact...but this is something that could be 'cured' easily with a hammer
And I have no such problems on the driver side:
So after I mounted them on the car and bolt them on, I drop the car and snap some pictures:
Passenger side - aside from small contact with the inner fender that can be fixed this side sure seems to fit:
Driver side - ohhh noo....this side doesn't seem too good :
And for some other interesting tidbits...I rolled them all through some light dirt.
275 40 17 on a 17x8 BFG DR = 8 inch contact patch at standard pressure
255 40 17 on a 17x8 BFG KD = 7.75 inch contact patch at standard pressure
Only benefit I gain (or IMO anyone else with a 65/6 mustang) with these is tire compound, IMO they can not be run on the street as it sits now and are only good for the straight line drags. Now I am hoping to figure out a way to gain .5 inch on the driver side, the passenger side easily fit the car, but given that I can't really get closer to the leaf spring than I already am I don't think there is a way to make these work long term for me and this car.
Bottom line: Half (arsed) fit.
Passenger side:
Driver side:
