MAF
Discussion in '94-95 Tech' started by TBCOBRA88, Nov 21, 2009.
  1. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    South Carolina
    95 cobra's came with 24lb. injectors right? If i am going to get a new maf do i have to do any tuning to the car other than get a maf already calibrated for cai and 24lb. injectors?
  2. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    Yes, they have 24lb injectors, but they use the exact same MAF as the GT. The difference in calibration is in the computer. So, in simple terms, you have to get a MAF calibrated for 19lb injectors. Or just call PMAS, and they will tell you exactly what you need.
    Kurt
  3. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    More importantly WHY do you think you need a new MAF? Not busting your chops but with no information as to mods on the car in the sig...you actually may not yet need a bigger maf and can spend the money on something that will be a bigger bang for the buck.
    The factory MAF is good to around the 290-300rwhp number give or take. If 24lb injectors are still ok for your fuel needs chances are your stock MAF is as well. Unless you can verify your pegging your stock meter (datalog, run some wires into the cabin to a digital volt meter) going to an aftermarket meter is probably not the best money spent.
  4. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    All good points and well said by Greg :nice:
    Another thing about the OEM meter working at the high end of its limit :)
    Its one thing to do that with pcm access ;)
    but
    Its another thing to try and do it with only mechanical means :Word:
    You are gonna be hard pressed to do it without upping the pressure a
    good bit and that can throw other parts of the tune outta whack :bang:
    I did it with 30's at OEM pressure
    and
    The fuel was spot on with good inj duty cycle :spot:
    but
    The little meter can only deal with so much before becomming overwhelmed
    Grady
  5. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    South Carolina
    Well, i have an aweful surging idle, and at 4200 rpm the thing starts cutting out on me under hard acceleration. The other day i was listening to the surging idle and i decided to unplug the maf, when i did, it ran beautifully. But today i unplugged it again, and it did not change a thing. Kept on surging..
  6. HISSIN50 "How long do you think it'll take me to get any he
    Jul 2, 2003
    Message Count:
    30,855
    78
    Have you tried another OEM meter? You might have a meter issue or some other issue, and running in FMEM masks it.
  7. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,644
    9
    78
    Massachusetts
    That doesn't necessarily mean the MAF is faulty.
    Do you have 24's on your car? Did you get a tune for them? If not, there could be your prob right there.
    Run your CEL codes first before throwing money at parts that may not be faulty.
    A list of your mods and what car you have would help too.
  8. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    South Carolina
    The car is a 95 cobra. 3.55 gears, msd ignition/and wires, flowmast catback, smog/ac delete, 88k miles.
  9. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    South Carolina
    Well, i decided to clean my IAC to try to fix the surging idle and once i got it all back together it ran great for about 10min. then when i lit myself a victory cig. it started again:jaw:.....
  10. Mustang5L5 Founding Member
    Feb 19, 2001
    Message Count:
    19,644
    9
    78
    Massachusetts
    Have youn run the codes yet? Just because the CEL isn't on doesn't mean there aren't codes stored
  11. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    South Carolina
    When i took my throttle body off to clean the iac i noticed there is no gasket??? this cant be right can it?:shrug: i mean, nobody has ever been into the engine so whats up with that?
  12. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    South Carolina
    Thank's for the help...:bang:
  13. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    Sorry, yeah you need a gasket there.
    Kurt
  14. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    There should be a gasket there. Also search on cleaning the maf itself with computer cleaner. A LOT of stupid issues have been caused by a dirty 94-95 maf.
Share This Page
