My quest to an 11 second car
Discussion in '94-95 Talk' started by Dizzy_ax, Apr 11, 2009.
  1. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    I have a thread up in the 5.0 talk but realized i should be over here :D its 7 pages long of the mods i've done to the car and how i felt about them/how they did at the track. Well i took a full bolt on car to 13.5 and then the track closed for winter. Now its re-opened and i have a H/C/I S/C and i have got it down to this!
    "11 seconds was staring right at me. but i can wait a little longer ;p
    Here are the new numbers with the same nittos as before! 315/35/17 Lacking sidewall ;p
    R/T .256
    60' 1.982
    1/8 7.950 WOO!
    MPH 94.62
    1/4 12.050 So close.... I actually had a group of people coming over to my car after each run and cheering me on...Holy crap thats a good feeling. And last but not least. my MPH...wich i have to say was scary!
    MPH 121.24
    I now see my breaks being an issue lol."
    I will post the time slip in the morning. Goodnight guys!
  2. Black95GTS New Member
    Jan 8, 2004
    Message Count:
    1,658
    Congratulations! You are all done with the engine, now its time to get that suspension and gearing in check. Easily a low 11, (high 10??) second car when you get it dialed in and are putting down 1.4x-1.5x 60 foot times.
    Adam
  3. RIO5.0 Mustang Master
    Feb 17, 2001
    Message Count:
    6,791
    86
    Yowza.... thats flyin...nice work...:nice:
  4. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    thanks! It should be fun to see what suspension and real traction will do to the car :) but i need to build up the rear end and a new clutch sounds good. so many parts, they should just appear at my door step for free!
  5. ProKiller Founding Member
    Apr 26, 2002
    Message Count:
    2,865
    58
    already some nice numbers. i'm sure you can break into the 11s with that top end
  6. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    thanks :D just have to figure out the suspension/maybe tires ;p and rear end
  7. inphiniti Active Member
    Mar 15, 2003
    Message Count:
    413
    26
    absolutely....
    that mph was up there too, did u have to change ur pants afterwards? i get nervous in traffic when i hit 100 LOL the comments from people at the track you dont even know must've givin you some nice support... keep us updateD!
  8. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    h:lol: Not yet ;p here are the videos and the time slip. Pretty much the car was hooking pretty good and my seat was too far back so i missed third and still ran a 12.8 lol... but here they are!
    Best run of the night, got it dialed in to .02 on the two good runs.
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG] Not sure what happened but i called it a night after that one ;p
  9. inphiniti Active Member
    Mar 15, 2003
    Message Count:
    413
    26
    not bad man... that car sounds like an absolute MONSTER! very very consistent
  10. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    it hurts my ears! lol. the guy in the RSX said "I have never heard anyone chirp second like that" Then he did his impersonation of it and i almost fell over laughing. (VroooooOOOOOOOOM VROOOSCEEEEEEEECH) :rlaugh:
    Right when i get there i had someone dissing on the guy that did my tune so it was good to throw some 12.0's in his face ;p
    edit: just wanted to throw in there that if im on a flat surface it takes ALOT of spinning to kick the side out. my car squats pretty good for stock suspension :) but i noticed more spinning as the gas tank was lowering so, maybe i only go fast from a stop with a full tank lol.
  11. Black Stampede Founding Member
    Sep 4, 2002
    Message Count:
    1,700
    36
    High 11s no problem, but I doubt you'll do any better then that with those tires.
  12. 1987Rock New Member
    May 3, 2007
    Message Count:
    113
    Awesome job man! :nice: That last run was kinda weird...sounded like it laid over a little...:shrug: Did you figure out what caused it?
  13. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    I might have not let it cool enough, i just wanted to do one more good run and then go, thats when i did the 12.050. So i figured thats really close and if i could bust into the 11's that would be awesome! but i shifted a tad bit slower and 2-3 gear was really slow lol.
    Also i find it hard to shift at the same point every time. im within a few hundred RPM but i think my fastest run i stayed in second gear untill 6250ish. with a little more practice and some more messing around with tire pressure i bet i could get in there pretty easy. second gear is just a spin fest and im invited :D
  14. 02 281 GT New Member
    Feb 3, 2009
    Message Count:
    154
    12.050 on a stock suspension car is sick! Just imagine what you'll put down once you get a real suspension under that car! Sounds great, by the way! That thing is screaming!
  15. thethirdeye88 New Member
    Apr 22, 2008
    Message Count:
    115
    nice...good job...
  16. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    thanks! cant wait. taking a short break but the modding/testing will be back to normal here in about three weeks.
  17. Farmers SN95 New Member
    Jun 2, 2006
    Message Count:
    81
    Dizzy_ax what gears do u have in the rear end?
  18. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
  19. ProKiller Founding Member
    Apr 26, 2002
    Message Count:
    2,865
    58
    i thought your car was opal? it looks white in those videos
  20. Dizzy_ax New Member
    Mar 27, 2008
    Message Count:
    88
    nope, its just crystal white. ;p
Share This Page
