So I been lurking the forum for a while just reading and reading trying to figure this out. I have a 87 notchback that ive owned for about 2 weeks. When I got it, no problems started fine. I swapped for a bigger throttle body and cold air intake now having problems starting. I replaced cap, rotor, coil, plugs, ignition module, reset timing, seafoamed the car after I replaced the plugs it fired up fine and that was the last time. It will start with starter fluid and stay running and I can drive it without issue. When I was resetting the timing and spinning the distributor I got shocked a couplw times from my hand ontop of the dist. Dunno if that is normal. When I ran my eec koeo I got codes: 22, 23, 85, 96 when I did my koer it popped 6cyl then codes 21, 23, 12. I am not surr what to do at this point just very frustrated. Any help is much appreciated.
