New shifter
Discussion in '2005 - 2009 Specific Tech' started by french2812, Jan 19, 2007.
  1. french2812 New Member
    Oct 12, 2006
    Message Count:
    91
    Just bought a new Steeda Triax shifter for my '05 GT. Looks to be a pretty basic install but does involve dropping the drive line. No info in the instructions about the torque setting when I reconnect the driveline to the tranny. Any know what that setting is or a link on the old WWW where I can find it?
  2. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    i dont know about the steeda shifter, but with a hurst shifter you dont have to remove the driveshaft. i was able to get it installed without removing anything, but it does make it easier to reconnect the dust seal at the base of the shifter if you remove the console.
  3. french2812 New Member
    Oct 12, 2006
    Message Count:
    91
    I can't see any way to get the Steeda around the driveline. Just not enough room. The instructions from Steeda are pretty specific other than torque settings. I crawled around underneath and their way looks to be the best.
  4. Mike97gt it doe snot
    Jan 26, 1999
    Message Count:
    12,475
    76
    Torque Specifications Description Nm lb-ft
    Driveshaft flange bolts 103 76
    Center bearing bolts 48 35
    Driveshaft constant velocity (CV) joint bolts 55 41
    Exhaust pipe nuts 48 35
    the first numbers are newton meters and the second set of numbers are lb-ft of tourqe
  5. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    thanks mike! you are the man. :)
  6. french2812 New Member
    Oct 12, 2006
    Message Count:
    91
    Thanks for your help!!
Share This Page
