bmorrisj
same here, just did a head up rebuild, blown gasket... bleh... and i have the same felpro kit with the rubber strips...
1105 said:so RC, did you ever get your problem fixed or are you still working on it?
FastmanGT said:we used a Fel-Pro gasket kit from Pepboys, it came with these blue rubber seals to use where the lower intake meets the block.
I just went to PepBoys and asked for the Felpro replacements for the Stock Lower.FastmanGT said:I honestly don't remember the part number, RC should be able to tell you, he just bought the same gasket set a few days ago.
1105 said:I would check first to see if everything has an even surface........ it'll only take a few minutes to check.
1105 said:If its eneven when you put new gaskets on, there might still be a place where oil can leak out because its not sealing in that one area. If there is I'd just put a little bit of RTV on it. I doubt there is a low area on your heads but when you go to put on the new gaskets, just check where the oil is coming out of just to make sure and apply some RTV if needed
