Pics of project 400rwhp N/A stock block 331
Discussion in '1994 - 1995 Specific Tech' started by Stopsign32v, Nov 13, 2008.
  1. It was an AFM N91 cam. Why don't you want to rev it high? :shrug:
    If I had a 347 I would look at a XE282 with possibly a set of 1.7RRs. I think that would be a nice cam. Or maybe a VooDoo stick.
    Also have you talked to Cam Motion Home Page ? They are some good guys and if you give them a starting point they might could cut you a nice cam. :nice:
  2. If you're interested in eliminating rear end squat when accelerating, get a pair of HPM's Mega-bite Jr control arms. I've installed them on both my Cobra clone and my GT; no more squat on acceleration. The reason cars squat on acceleration is because the pinion angle causes the axle to pull up, thus pulling the wheels away from the pavement. This is not what you want. The Jr's alter this angle so the axle pushes downwards, pushing the tires into the pavement. I can still squeal my tires in both cars, it just takes a bit more work.
  3. I can't find the specs on the Anderson N91 cam, but oh well. My current camshaft is bigger than the XE282HR. .574"/.595' 110 lobe sep and 236/248 @ .050". I don't want to rev it up high, because it's an old and tired stock block 2 bolt 347. Right now I'm shifting at 6200rpms which seems to be doing pretty well. Max power is at 5650rpm.
  4. What did u do to the heads/shortblock to get it to rev that high(or to just make that power in general)
    Any lightweight components?
  5. stopsign32v
    Last Activity: Today 04:39 PM
    I guess I need to play the lottery...:rlaugh:
    Thanks for the update Stopsign..Some people had counted you out..:nice:
  6. Dito on the Heads, Where did you get the springs? or were they out of the box on the heads?
    Nice deal btw, sweet car and vids.
  7. Heads are the 205 TW ones and the springs I can't remember which ones I went with. Its been so long ago.
  8. Matt, I don't disagree with you much around here, but what you just posted is :bs:!
    In straight line racing OF COURSE you want the rear end to squat. It helps tremendously with weight transfer. Now wheel hop is another matter and one I believe is more related to pinion angle and binding.
  9. No actually he is correct, you don't want the rear end to squat. That is wasted energy. You want to plant the tires into the ground instead. Obviously there will be some squat and that is what I was talking about, not alot though.
  10. talk to me about the valve train and rods/pistons
    did you go with the absolute lightest ones you could find to support revving it so high?
    or what did you go with?
    my next build (if there is one) would have a goal of being able to quickly rev it to 7500
  11. I know Im a dumbass :(
    Thanks for the update stopsign :D
  12. Im confused on the whole spring rate thing.:shrug: My 331 is sitting on the stand, Pro Ibeams and probe pistons, AFR 185 Heads, stock springs and a ford B cam..:notnice::nonono:. So im all drag race now and want this baby to spin some Rs!!
    what do you think?
  13. Yes the valve train is light, I focused alot on the valve train and the valves themselves. Sorry to say guys but I really don't want to go into detail there. :(
    But you are also correct on the rotating assembly. I knew I wanted it to rev fast but I had a budget. So I chose to go with a cast crank, its a Scat crank. And I went with some FORGED Scat I beam rods. The pistons are just Trickflow pistons. If I could do it over again I would coat the pistons though. Wish I had done that. But my rotating assembly is nothing special, very cheap parts you can get out of Summit.
    Now I cannot say for sure and someone may argue with me and that is completely fine. But on a stock block I would be alittle more nervous about reving a 347 that high. The added stroke pushes harder on the outside of the cylinders and that is just added stress.
    Also IMO if you are going to rev a motor that high a main girdle is a must and so is some rocker arm stud girdles. And before someone says the main girdle does nothing but keep the block together after it splits, you are wrong. The main girdle also helps keep the caps from walking, one of the causes of a cracked block.
    Hope that helped some.
  14. Don't worry, he is the one that PMed me to update it. So he cheated really. :lol:
  15. Why would you put a B cam in a 331 with AFR heads? :nonono:
  16. Yea, I know, Im a cam tard, plus I built it 10 years ago with little or no help.
  17. Totally agree. My engine is without a main girdle, or rocker girdle. Low Revs for me.
  18. Throw on a Trickflow R series intake and change the cam. Not hard to do and you would pick up alot.
  19. Got the intake, been running the R for along time. Just need the cam i guess. I looked at the n91 last night, but I thought it might be a hair to big.
