Pics of the heads that just came in for the stroker. *56k no way!*
TFS Twisted Wedge 205cc with alittle bit of work done to them. :D Started out of a bare casting, CNCed them, then modded them alittle bit more, and finally put the lightweight springs, valves, and Ti retainers on them. Should be good heads for a 7,400rpms shift point. :nice: Still waiting on the 3/8" studs and the stud girdle.
LSX valve springs
"I'd get in there and polish those ports as smooth as silk before going any further."
I've read you don't want the intake side polished too much. You want a little tumbling of the air to help the air/fuel to mix. The exhaust side you can polish all you want.
On a carbed car yeah. The slight roughness helps keep the fuel in suspension as it heads through the port. On a port fuel injection car it's not an issue.
Nice looking cylinder heads!
I would suggest 7/16" studs.
I know how to build motors. ;) But thanks for the info.
When using a girdle it eliminates the movement of the studs on the 3/8", the nuts on the 3/8" studs are much more beefy, and the rocker trunnion is significantly thicker with the smaller hole drilled through them rather than the larger 7/16" hole. :nice:
Its not, anymore there used to be problems with burning oil because of how they used to be designed but over the past years they have cleared it up. BTW what block are you using? Stock block+7400 rpm+a little time= your $2000 heads junk when it splits.
Why is a 347 less reliable than a 331?
Just going by what I heard. The oiling issue and my engine builder says they have a problem with putting more stress on the sides of the clyinder walls because of the extra stroke. I'm not saying any of these are true I just do not want to find out myself and this combo is gonna make more than enough power for now so I will not miss the 16cid difference.
Cute picture though. :nice:
