Just want to see if this maybe a issue. I'm getting a set of trick flow track heat heads and trick flow stage two cam on a stock block. Is there going to be a issue with piston to valve clearance? I plan on checking during assembly but just dont need any more down time once I tear it apart. The head part number is 51400010. The cam specs are
Part# TFS-51402001
Cam Specs:
Basic RPM Operating Range- 2,500-6,000
Duration @ .050- .224/.232
Lift- .542 int /.563 exh
Lobe Sep- 112*
Grind #- HR-236/359-2S1-10
Part# TFS-51402001
Cam Specs:
Lobe Sep- 112*
