We're starting a build on a '02 GT that we picked up last week. I got a sweet deal on the car.. 12K and it has the following stuff done already..
Vortech V2 SQ blower (2k miles)
12lb pulley with meth injection
Comp 274 Extreme's (236/240*, .500" lift, 114 LSA)
Comp springs/retainers
BBK shorties
BBK X-pipe
Flowmaster 40 series exhaust
King cobra clutch
5spd car (3650 in great shape)
Built 8.8 rear with moser 31 spline axles and Auburn diff
Strange 10 way adjustable's
Upper/lower control arms
Battle boxes welded and bolted in
Subframe connectors welded in
Aftermarket aluminum driveshaft.. (not sure what brand)
C&L Plenum
Accufab 75mm TB
42lb injectors/L-maf with SCT tune
New brakes and bushings all the way around
Mach 1000 audio (I've never seen this in a Mustang before.. insane)
18x9.5" Cobra R polished aluminum wheels
Eibach springs
Spare aluminum block to build
03/04 Cobra tank with twin pumps installed
The car made 460rwhp at 12psi with meth injection, as is..
The goal... is to get this car into the 9's, reliably, for 9K or less. So far.. here's the game plan..
JW TH400 trans (good for 1000hp) with Ultra-bell
JW converter (4000 stall)
JW SFI flex plate for 4.6
Modify the existing aluminum drive shaft
Cobra crank
Manley H-beams/arp bolts
Probe 18cc dish pistons
Existing comp 274's and springs
New oversize valves and port work by moderncylinderhead.com
Federal Mogul race bearings
New Ford gasket kit
Felpro MLS head gaskets
ARP head and main studs
Cobra oil pump
Used JT-trim blower upgrade (Brandon @ MPH)
Front mount bar/plate intercooler setup (built in-house)
3" intercooler piping with Tial blow off valve
Existing 90mm L-maf in blow through, with MPH MAF-Extender
60lb Mototron injectors (have a set laying around)
Steeda fuel rails (have a set laying around)
Twin ford GT pumps (upgrading from the stock Cobra twin pumps)
P-51 Intake manifold (picked up used for a smokin deal)
Firebottle fire suppression (already have in the shop)
10 point cage (getting for free.. local race car fab guy owes me a favor)
Harness, HANS neck device, helmet, fire suit (have already)
The only thing that I haven't addressed is what to replaced the Eibach springs with.. Other than that.. I think I have it covered. I need a NHRA license too.. I'll be tearing the car apart this week for the cage.. I'll post pics as the project progresses. I am still under 9K so far.. well under it.. I still have to pay for some machine work, and a few odds/ends.. I think I'll be in under the cap though.
Travis
BBK shorties
BBK X-pipe
King cobra clutch
C&L Plenum
Accufab 75mm TB
Eibach springs
Cobra crank
New Ford gasket kit
Cobra oil pump
Travis
