Progress Thread Raceoholic330's Restoration Thread. Dart 331, Turbo, Irs, Etc...
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by RacEoHolic330, Nov 14, 2011.
  1. RacEoHolic330
    RacEoHolic330 I like to dress like a pretty girl SN Certified Technician
    Mar 5, 2003
    3,504
    590
    153
    That is what I'm trying to avoid. I have enough stuff to fabricate on this car, build a sub encloser is not something I have any interest in doing. The loaded enclosure Power Acoustik sells is real nice, it's just too long. The pioneer enclosure is slightly smaller in width and length that the one I have now ( its much thinner though).
    13" is a moster of a subwoofer. It would be cool if I could find a small enough enclosure for that PA woofer.
    And yes, once you have bass, it's very hard to live without it.
  2. rangerboy101
    rangerboy101 Active Member
    Oct 11, 2011
    330
    22
    28
    I really like that battery "tray/box". Looks so much better than a normal battery box.
  3. Rick 91GT
    Rick 91GT SN Certified Technician Site Sponsor
    Nov 30, 1999
    9,747
    94
    99
    Scott I have a Taylor tray and hold down setup at the shop....you can have it if it works for you.
  4. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    I may take you up on that Rick. Something like that will probably be the best way to tie down the battery.
  5. Adams91LX
    Adams91LX Active Member
    Dec 9, 2003
    702
    9
    29
    Honestly, in the small space of this car, a 10" is plenty of woofer. I might think about doing a custom fiberglass spare tire-well enclosure... up to you.
  6. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    Oh yea, my 10" Alpine that I had in there previously would shake the interior screws out of the car. I think I'm going to pull the trigger on that loaded pioneer unit. It will make my life easier and all I'll need to do it fab up some brackets to mount it to.
  7. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    Made some progress on the false floor today. Framed it all out of 1/2" square steel stock. I decided to elevate the level of the floor frame 2" above the hatch floor. This will give me plenty of room for the subwoofer as well as clearance for a battary as tall as an Optima Red, if I decide to get one down the road.
    Here's some of the outer frame for the back half of the hatch:
    [​IMG]
    I had to leave the top end open so I can fit it around the roll bar. The front brace had to be welded in the car.
    [​IMG]
    Tacked the front brace in and welded in all the 2" spacers:
    [​IMG]
    After addng the front pieces. This will cover all the electronics under the rear seat area.
    [​IMG]
    [​IMG]
    [​IMG]
    I didn't weld in all the supports, so there is still more to do. The welding fumes started getting to me due to the lack of ventilation in my garage! I will also be welding together another frame that will fit inside the outer frame around the rear seat area. It will hinge on a pair of gas struts so I can access the electronics below.
    This whole false floor will serve at the mounting point for the carpeted MDF floor that I'll be making when the time comes.
    My turbo will finally be here this week, so I hope to be able to finish up the exhaust work next weekend.
  8. madmike1157
    madmike1157 the humor is still lost on me SN Certified Technician
    Nov 30, 1999
    3,689
    852
    154
    Coolness, just freakin' coolness.:cool: If I'd only waited until you started this build,.....The ideas I could've stole:nonono:
  9. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    Haha. Thanks Mike. Imitation is the finest form of flattery, right?
    Here is the plan for the hinged lid that will cover the electronics area. Try not to be too jealous of my MS Paint skills!
    [​IMG]
    The red is the welded frame, the yellow is the piano hinge, and the blue are the gas struts. If it is not strong enough, I may weld in two more cross supports to create two x's. We will see.
    I've been searching out gas struts online. Seems like many of them are meant to lift some serious loads. They all have huge opening forces (20-100lbs each!). I'm lucky if the whole lid will weight 20lbs even with the MDF and carpet. I found a set of 12" long struts with a stroke length of 8". This will give me a 20" extended length, which I think it what I will need to raise the lid high enough for it not to be in my way to access the area below. They are also only 10lb struts, so I think they will do the job without launching the lid into the air like a catapult. Statics are not my speciality, so this may wind up being a trial and error type of deal. I think those struts will work though.
  10. madmike1157
    Nov 30, 1999
    3,689
    852
    154
    You give away the ending. with your posts there's nothing left to imagine.:nonono:
    It was the same for me on the trunk. After adding that 18 ga spoiler on the tail and getting rid of the factory torsion bar, it was pretty heavy. I had to b itch out an O'Reilly's guy because he didn't want to open the catalog to let me see extended/collasped, and weight ratings for the different struts they had access to. I got to take each one back (starting w/ 27 lbs,) then 39, finally 47 lbs) It now lifts on it's own after it gets 1/2 way up. But, I've already weathered that storm. ( I was rushing to your aid w/ my vast knowledge on the subject,:rolleyes: but read on to see you solved your own problem)
  11. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    Do you think two 10lbers will be enough to lift that lid based on the areas where they will be attached to? I'm not sure how their attachment points change the physics regarding their lifting leverage or lack thereof.
  12. madmike1157
    Nov 30, 1999
    3,689
    852
    154
    well unfortunately, I don't have the math figures to figure the intersect angle either. Besides I was regulated by the mount points for the things while collapsed vs how high I wanted the trunk to get when open, so being able to move that mount point was minimal for me. It took me three times to get it right, the first time the shock didn't lift the trunk at all and would only hold it open. Going up 10 lbs would still not lift it, but would hold it open over a broader range. The final version ended up doing the trick, basically they take the trunk away from me after it gets half way open. The only other byproduct of having to deal w/ a progressively heavier lift force was the tendency to push my trunk alignment out of whack.
  13. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    I think I'll buy a pair of 10 lb struts as well as a pair of 20 lb struts online and see what works. They are a whopping $10 each, and being that Auto Zone wanted around $25 each for struts of unknown force, I'll just use whatever doesn't work to open the toilet seats in the house or something :banana:. The guy at auto zone was at least nice enough to let me go to town pushing all their struts against the floor to see which ones would compress easily. They didn't have much to choose from, unfortunately.
  14. Rick 91GT
    Nov 30, 1999
    9,747
    94
    99
    You ever look at the set-up Scott Rod carries for the rear seat/area delete...very clean.
    You want the battery tray?
  15. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    I do really like the Scott Rod setup. Doesn't work for what I'm trying to accomplish, but it does look awesome.
    I'll pass on the battery tray for now. I don't think an actual tray will work for me. It will raise the battery too high. I will probably just do the threaded studs with a strap between to hold it to the floor. Thanks for the offer tho! :)
  16. Ozz
    Ozz I think I have a problem here. Founding Member
    Jul 27, 2001
    3,724
    22
    59
    Very impressive, Scott. I like the heater tubes idea, that came out pretty slick!
  17. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    Thanks Dave. Much appreciated. I wish I could take all the credit for the heater tubes. Found a thread on the corral with a guy that did the setup and he had a nice parts list of how he did it. I made some tweaks and made it work for me. It should get the job done!
  18. Ozz
    Jul 27, 2001
    3,724
    22
    59
    You're welcome, it's highly deserved. Part of me would love to do a project like this but I think a bigger part of me knows better :lmao:
    I saw you mention how you got the idea but it's still neat to see. Plus you put your own tweaks on it, which is good enough to garner some praise I'd say. If I didn't just chrome plate mine (I'll have pics in my winter projects thread soon enough), after seeing yours I probably would've thought up doing something similar and putting my own spin on it too.
  19. RacEoHolic330
    Mar 5, 2003
    3,504
    590
    153
    Well, if you have money to blow on AN fittings, let me know and I'll tell you the fittings I used. I have a good amount of 1/2" tubing left too that you can have also.
    Ozz likes this.
  20. Rick 91GT
    Nov 30, 1999
    9,747
    94
    99
    Man I cant wait to start digging into my car again, this thread makes me happy:p
    I got an email from Vibrant, their boost controllers are on sale through Friday if your interested
Share This Page
