xYoung347x
- Nov 3, 2003
- 382
- 0
- 0
the only way the 331 pushing 420hp is the guy has a roller cam w/ some bad@ss spec/ big heads (AFR 205 heads) and hes shifting about 7500+ rpm.
Grn92LX said:Theres a guy on here (ninjacoupe) making just under 400rwhp with his 347 witha small afr 185 head. Its VERY easy to make over 400hp on a 302 stroker if you know what your doing. AFR 205 heads or the FTI stroker series 185's, ported TW's, ed c cam and an rpm2 intake (or similar) and your over 400 easily. Lots of guys call BS because they have a 331 or 347 with JUNK parts that is slow, so of course no one else can make better #'s Those same people wonder why their E cammed 347 won't even run 12's Do your HW, making good power (over 400rw within streetable rpm's) with a 302 stroker is EASY, but is pricey..
Im talking about having to have a certian amount of vacuum... And then the computer being picky...GTJake said:Like what?
Jake
moneypit94 said:Im talking about having to have a certian amount of vacuum... And then the computer being picky...
whats the dyno numbers? we have almost the exact same combo.twstd50 said:Here's my combo:
331 w/all forged internals
xe274hr
TFS track heat intake
off the self TW heads
Bassani o/r x
spintech prostreets
pullys
4.10s
3000 PI converter
BBK headers
1.6 rr
Aluminum Drive Shaft
24lbs squirters
190lph fuel pump
fpr
70 mm tb
75 mm pro m
all a/c deleted
C&L True Flow inlet pipe
It doesn't put up the best dyno numbers but I'm able to surprise a lot of people at the track... being that it's a heavy vert on 18'' radials.
