So as luck would have it I was looking for a new set of heads for my 347. I found a set of Canfields at a shop that had some damage. The guy said they were very fixable and you would not be able to tell they had every had work done. I offered $800 for them if he fixed and freshened them up. He said no way, so I went looking elsewhere. I bought a set of New in the box RHS cast iron heads 200cc from a guy for $760(smokin deal). Guess who called and said he would take the $800 offer.
So now I own 2 sets of heads, Which ones to use is the question. The Canfields are better prepped as they have been ported and have 7/16 studs and 10* locks and of course are alum and the springs are set up for a solid roller. But my fear is they may be a little over kill. The RHS are set up for a solid flat tappet with .56 max lift.
The car is set up as a road course car with some limited street use. I would like a broad torque curve and would give a little on the top end to get it 2500-6800 rpm. Compression is around 10.3 with either head.
I have both a RPM air gap and old torker single plane (could use either)
1,5/8" long tube headers, 750 HP DP or 650 Mighty Demon Carb(could use either) 3.70 gear and T5z tranny. I will be buying a new cam to match what ever combo I go with.
Looking for any input you guys have to help make this a winning combo!
