Rubber Bushings
Discussion in '94-95 Tech' started by 95Monky, Feb 7, 2012.
  1. 95Monky Member
    Jan 4, 2003
    Message Count:
    191
    Chico, CA
    Where can I buy factory rubber bushings for the suspension?
  2. Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Jan 5, 2011
    Message Count:
    10,821
    378
    133
    Box behind Walmart
    Which ones?
  3. 95Monky Member
    Jan 4, 2003
    Message Count:
    191
    Chico, CA
    Prefer a kit like what you can buy from LMR made with plastic
  4. Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Jan 5, 2011
    Message Count:
    10,821
    378
    133
    Box behind Walmart
    Hmmm... I think you're talking about the Prothane total kits...
    If that's it then that's what I'd go with. I can't think of a reason why you'd want them to all be rubber with exception of the upper control arm bushings.
    Were it me, I'd get a complete urethane bushing kit and either a set of OEM upper control arms or just the rubber control arm bushings from Maximum Motorsports. http://www.maximummotorsports.com/store/index.php?main_page=product_info&products_id=543
    If you're hell bent on getting rubber bushings, you should be able to get them individually from your favorite parts store.
  5. 95Monky Member
    Jan 4, 2003
    Message Count:
    191
    Chico, CA
    Thanks for the reply. I was looking for a complete kit of rubber bushings. I do not the hardness of plastic bushings.
  6. Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Jan 5, 2011
    Message Count:
    10,821
    378
    133
    Box behind Walmart
    I can't recall ever seeing the rubber bushings in a complete kit form.
  7. 95ssn95 Member
    Nov 4, 2008
    Message Count:
    41
    Missouri
    I have been thinking of doing a complete urethane bushing kit. What are your concerns about the harder bushing? My stang has 177xxx mi. and could benifit from some new bushings and I have never had the luxury of comparing it to a stang with a "tighter" suspension or anything with urethane bushings. Just wondering.....
  8. Chythar Active Member
    Aug 26, 2004
    Message Count:
    1,878
    48
    West Los Angeles, CA
    Never seen a replacement rubber kit either. Energy Suspension's bushings are supposedly softer than the ones offered by Prothane, but they're both harsher than the OEM rubber.
  9. 95Monky Member
    Jan 4, 2003
    Message Count:
    191
    Chico, CA
    Thanks for the insight. I will check out Energy's products.
  10. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,685
    68
    Acworth, GA
    You have to buy them individually. Any parts store can get them.
    Kurt
Share This Page
