Occasionally, the car will run warm if idling in place with the a/c running. Warm meaning to the point where the needle is obviously past the half point, and warm to the point where I had to shut down and put the heater on a few times.
The coolant tank is full when the car is cold prior to start, so I'm not low on fluid. During my last oil change, I checked the underside and nothing "appears" to be leaking.
Any suggestions on what else to check, or anything I missed?
