Should I Buy? Need quick answers please!
Discussion in '94-95 Talk' started by Tom95gt, Nov 9, 2009.
  1. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
  2. Adam95GT New Member
    Aug 14, 2006
    Message Count:
    2,600
    Depends on your plans and what parts you would be using or selling... You can get an explorer engine with lower miles for cheaper... however you dont get the 94/95 cobra valve covers , manifolds, and cam... it looks like a decent deal... but like i said it all depends on your future plans... are GT40's going to suit your needs... what about the cam and manifold....
  3. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    As long as the motor holds the boost, I would like to just drop it in my car.
  4. Adam95GT New Member
    Aug 14, 2006
    Message Count:
    2,600
    If your going to boost it it will be fine... But i would want new rings,seals,gaskets still... if that thing has stock head gaskets you will probably blow them anyway
  5. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    Yea that would be a lot easier to do with the engine out of the car and I should make a little more power cause the cobra engine will flow better.
  6. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,229
    68
    Probably a good deal for what you want to do. I imagine the big quesiton is How long has that engine been sitting? I would bring a breaker bar and socket with you when you go look at the enigne. Just make sure you can turn it over easily. At $850, you can take it apart and freshen it up, and it will still be a good investment.
    Kurt
  7. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    Thanks you wouldn't know off hand what the size of that bolt is? I think a 1 inch maybe no that's too big
  8. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    I'm getting it for $600 with my 10th anniversary cobra brakes
  9. Adam95GT New Member
    Aug 14, 2006
    Message Count:
    2,600
    13/16.... 11/16..... 21mm.... 24mm.... all numbers that are in my head for that for some reason... LOL
  10. Adam95GT New Member
    Aug 14, 2006
    Message Count:
    2,600
    im leaning more on the 21mm actually... like 95% for the crank bolt.. mind you thats off the top of my head...
  11. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    lol thanks
  12. Grn92LX Fidanza Man!
    Jan 14, 2001
    Message Count:
    6,627
    76
  13. RIO5.0 Mustang Master
    Feb 17, 2001
    Message Count:
    6,791
    86
    Thats what I was thinking...
  14. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    Well I picked it up so now what should I do with it? Drop it right in, throw new gaskets in it, Rebuild it?
  15. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    Probably do a bigger oil pan but one that fits with stock k-member
  16. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,229
    68
    Well, I guess the bear minimum is a new rear main seal and oil pain gasket. Those are a lot of work to change once the engine is in the car. I would pull the oil pan off first, and see if there is any nasty oil, corrosion, and damage to the cylinder walls. Check the timing chain too. If you have any extra cash, it wouldn't hurt to pull the heads off and get a look in the top too.
    Kurt
  17. Chythar Active Member
    Aug 26, 2004
    Message Count:
    1,851
    48
    Kurt has a good point, money is really the issue here. How much do you have to spend? A complete rebuild is always an option, but that will cost money and time. I would add to Kurt's list a new oil pump. You can look at the cylinder walls while the heads are on and see if the crosshatching is in place, or if a piston is cracked or any broken rings.
  18. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,229
    68
    Excellent point on the new oil pump. A new oil pump is only about $20.
    Kurt
  19. Tom95gt New Member
    Oct 10, 2007
    Message Count:
    186
    Basically no money now lol. Definitely needs a new oil pan so I might save up for a bigger one. I was thinking about putting new head gaskets on it too. I guess I'll see what happens. This motor should just drop right in right?
  20. Chythar Active Member
    Aug 26, 2004
    Message Count:
    1,851
    48
    The motor will just drop in. The motor mounts and all engine wiring harnesses are identical. However, your GT computer won't know about the bigger fuel injectors, heads and intake; it'll probably run poorly. You may want to look into getting a chip for your GT computer and loading the Cobra tune (J4J1) on it. If you're going for low cost, I recommend the Moates.net chips. They're cheaper than the Tweecer but you'll probably have a steeper learning curve for tuning later on. But loading the J4J1 on a chip is really easy.
Share This Page
