- Nov 17, 2007
- 13
- 0
- 0
okay i have a 1990gt and everything is brand new it is a 306 with kieth black pistins,ecam,trickflow aluminum heads,trickflow 1.6 roller rockers,holley upper and lower intake,holley 70mm throttle body,bbk 70mm egr spacer,bbk cold air intake,24lb injectors,holley 190gph fuel pump,bbk adjustable regulator with liquid filled gauge,granttelli 24lb mass air meter,msd pro billet distributor, and its like i cant get the timing right but i know it is i set the timing mark on 0 on the compression stroke and put it on number one and it wont idle it will run but it skips and pops when ugive it gas and yes the timing chain is perfect check it twice i really dontknow much about adjusting the valves but i read the book and did everything it said to do and it still wont run someone help me get it running before my wife kills me thanx
