T5 transmission problem PLEASE HELP
i noticed a very simliar recent thread on this but wanted to post mine bc i did not want to hi jack theirs...
a friend and i just done a t-5 swap on my 95 with a t-5 from a 95 cobra. we took everything out down to the flyweel. i had the flywheel that came from the cobra resurfaced. the clutch is a centerforce and only had about 12k on it. we replaced everything and installed the 32k cobra t5 and went for a test drive. vibration is horrible. its very noticeable at crusing speeds. the clutch engages fine and the trans shifts ok ( noisy tho...or about the same amount of noise my 110k gt trans made ) but no grinds. there was no vibration before with my stock t5.
a few people have mentioned that my driveshaft is out of balace....but how could that be if it did not vibrate before? could the splines not be lined up the same? does that make a difference? is there a wrong way the input shaft goes into the motor? am i doing damage? im afraid to drive it. could exhaust rubbing the driveshaft cause that much vibration?
another thing someone mentioned was the input shaft bearing....could that be a problem on a 32k trans?
PLEASE HELP
PLEASE HELP
