Yes you can turbo your car but i highly recommend you get your motor built with forged internals for reliability. Also it doesn't matter if your car is automatic or not. You will also have to upgrade your fuel system such as fuel pumps, fuel rails, and injectors thats roughly another 1200$ in parts. you will have to have a DYNO tune. DO NOT get a mail in order tune you will not see peak performance. I personally wouldn't go with turbo. I recommend you go with kenne bell or pro charger . In any case the max boost you would probably be able to run on a stock 2v would be about 10psi. By the time you get a built engine and turbo exc…… you could buy an 03-04 cobra, just a thought.
