Well the motor blew up tonight...
Discussion in 'SN95 4.6 Talk' started by SHOWTIME!!, Feb 5, 2009.
  1. SHOWTIME!! New Member
    May 14, 2008
    Message Count:
    15
    We finally got my nitrous lined out tonight, so we go out for a test drive. The bottle pressure is at 1000psi. I do a 3rd gear pull and the car is pulling really hard. I decide to run threw the gears from 2nd, i nail it in 2nd and go to hit third and boom. It starts sounding like an exhaust leak and it has a dead miss. We pull the number 1 plug out and it has the entire top burnt off, we change all the plugs, still has a miss. We change the coil pack, still has a miss. Long story short we did alot of test and everything had the same result, dead miss. So i go and get a compression test gauge and sure enough, 10psi in cylinder 1. It already has a forged crank so im keeping it. I think im going to put some good rod bearing and buy some forged pistons that will bump the compression up a little, get my machine work done and maybe throw some cams in it. I would buy heads but i dont have that kind of money.
  2. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,642
    36
    Jesus, everyone is building new shortblocks now (ironically mostly nitrous guys). Am i the only one who builds up BEFORE the poweradder? I guess if it doesnt ruin the block or heads you're not losing anything that wouldn't be replaced anyways though.
    Keep us updated, man!
  3. SHOWTIME!! New Member
    May 14, 2008
    Message Count:
    15
    We only had a 100 shot on it. Had 2 degrees of timing out of it also. I dont see why it would have put a hole in the piston. It just doesnt make sense, there isnt a v-8 out there that can't handle a 100 shot (well aparantly there is now! haha)
  4. CobraRed_96_GT Active Member
    May 20, 2006
    Message Count:
    1,642
    36
    100 dry shot? Maybe you peaked fuel duty cycle? Or, all it takes is a bad fuel filter or pump and kablammy.
  5. CatmanJJ Captain Tangnet
    Feb 5, 2002
    Message Count:
    4,578
    That sux, mine has been sitting since end of October as well waiting for a rebuild.
  6. SHOWTIME!! New Member
    May 14, 2008
    Message Count:
    15
    No it was a wet kit.
  7. deftsound Please ask me how much my supercharger cost
    Apr 6, 2004
    Message Count:
    1,681
    Next time get it tuned before you gas it
  8. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,752
    78
    What fuel pump are you running? What jets? Did you remove the performance tune and then pull 2* or pull 2* from the performance tune?
  9. BurningRubber Active Member
    Dec 6, 2004
    Message Count:
    2,691
    48
    That sucks man, how many miles were on the motor?
  10. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Damn that blows. I haven't even tested my N2O yet. I'm waiting till i get all the safety parts first, and a wideband.
  11. 02LaserRed2V New Member
    Jul 31, 2004
    Message Count:
    399
    Congrats! I think lol
  12. Poisoned Pony Founding Member
    Dec 18, 2000
    Message Count:
    288
    half the fun is blowing up the stock stuff 1st :D
  13. Omars96GT New Member
    Sep 13, 2008
    Message Count:
    maybe you had the wrong fuel jet or fuel pump is not working right..... also i always step up a little the fuel jet so if the kit says put a 34 for fuel i put a 36. remember its better to be rich then lean lol
  14. SHOWTIME!! New Member
    May 14, 2008
    Message Count:
    15
    it had a 34 fuel jet and a 51 nitrous jet. It was running on the stock fuel pump that was replaced about 40k miles ago. The timing was set at stock. Do you think that the fact i was running a platinum plug might have had something to do with it? I found a teksid aluminum block, cobra forged crank, forged H beams, and forged pistons. I also got a set of hogged out PI heads. Believe it it not ( i believe it because i saw the flow charts) these heads flow a little over 250cfm @550. He said he has about $1500 in port work in them. Im also going to buy a set of cams, do you think i still should go with the HiTechs or should i step it up a little bit to a bigger cam with that much flow and a 150 shot?
  15. Nitrous03GT New Member
    Nov 22, 2008
    Message Count:
    17
    first we need more info...you say you "nailed it in 2nd" what RPM did you nail it from? 1k? 2?
    there is no way you should have blown the motor on the first test runs on a 100shot unless a) your motor was already poop
    b) you installed in wrong
    c)your timing wasnt stock
    d)you shot the juice too low in the revs
    and yes, get rid of plat. plugs, run 1-2 steps COLDER copper plugs.
    also, dont go messing around and mix matching jet sizes either, you'll either get it wrong or run so rich that you make less power than you would on a smaller shot in the first place.
    i've run probably over 150 30# bottles of straight 125 shot with NO tune and no fuel system upgrades through my motor with ZERO issues. n20 is safe for an engine as long as it is properly setup and run.
  16. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,752
    78
    I would bet the fuel pump wasn't sufficient. You already had a good number of mods, probably taking you to around 300 at the crank. Then, add 100hp of nitrous and the stock fuel pump just couldn't supply enough fuel.
  17. Nitrous03GT New Member
    Nov 22, 2008
    Message Count:
    17
    the only real power mods he has when he is on n20 is the hpipe, plenum and TB, he's nowhere near 300 at the crank and even then a 100shot isnt going to bump him over the fuel limits
    i'm running- demolet intake, plenum/tb, pulleys, prochamber and catback as my power mods and i'm not near 300crank HP on motor and i run a 125 shot that makes 376hp at the wheels and have no issues..
    it comes down to something wasn't right, either motor was already dying, n20 wasn't installed right, sprayed too low ect...
  18. Stark77 New Member
    Jun 11, 2008
    Message Count:
    503
    Agreed - I run a 125 wet shot with no problems on stock block.
  19. SHOWTIME!! New Member
    May 14, 2008
    Message Count:
    15
    I was at 3500rpm when i sprayed it both times. I didnt miss match the jets, that's how summit racing sent them to me. No as for it being installed right that's where in my opinion something went wrong. I didnt install this kit, i dont know how to install nitrous. I took it to a friend of mines shop and dropped it off for him to do it. Everything looked fine but where the shark nozzle is located at. He put it on the throttle body, like he drilled into my throttle body and that's where he mounted the nozzle. I had asked him if that was to close and he said "No man it's fine, that just means it will hit harder". We argued about it and argued about it and finally he said "Fine lets go make this nitrous pass and then we will move it". Well you know the rest of the story after that.
  20. Nitrous03GT New Member
    Nov 22, 2008
    Message Count:
    17
    where in the TB did he drill it? i dont know that it would cause failure having it drilled there UNLESS the nozzle obstructed the butterfly from opening and that cause all the n20 and fuel to go in but not enough air, but i can imagine you'd be able to tell something like that was happening before you sprayed it...
    how many miles are on the car, it is possible that your engine was getting weak and the extra power just sent it over the edge.
Share This Page
