the situation..
1991 Ford Mustang
ECU AND Wiring to ECU removed
Carbed 302 (306) in the process of being installed
AOD REPLACED with C4
ALL gauges being replaced with Autometer Guages
Need help laying out the wiring... the gauges in green I have under control.. the ones in red I need a hand with.. I listed the ones I "know" just in case I screwed something up.. lol also was wondering if I could simply tie into the factory harness behind the cluster OR if those wires went south with the ECU and ECU harness removal?
is there a factory sensor I can remove? no ECU so don't need any of the factory stuff? where should I locate this?
Oil Pressure - ?
Water Temp - ?
Tachometer - ?
Fuel Level - ?
Fuel Pressure - mechanical mounted on cowl ran to port on fuel line near carb
Trans Temp - sensor inline to cooler
Speedometer - remove speed sensor from AOD and install in C4
Vac - T in vacuum line
Nitrous Pressure - to solonoid
Pyrometer - wired to sensor in exhaust
thanks in advance!
1991 Ford Mustang
Oil Pressure - ?
Water Temp - ?
Tachometer - ?
Fuel Level - ?
thanks in advance!
