jcgafford
base idle is factory set a little above 600 rpm. i have done the cleaner thru the vacuum system with no ill effects, never know though.Thanks I will go look for that thread. I was already thinking about replacing the O2 sensors just because I don't know when the last time they were replaced at. Could bad O2 sensors be causing the idle problem I am getting on start ups when it's been sitting over night or for many hours? I also noticed sometimes at idle at stop lights the idle drops down to about 600RPM. I tap the gas and it comes back up a little and stays but will go back down. As much as I want to start spending money on go fast parts I want to make sure the car is running properly before doing anything else. I also noticed that today when I got on the gas pretty good it felt like it wanted to stumble a little.
So far I will be ordering new plugs and wires, fuel filter, O2 sensors, clean the k&n filter, clean IAC, TB, do you guys recommend fuel injector cleaning that you dump in the tank? I also have one of those drip lines that can be attached to a vacuum line, but afraid to use it on an older car because I've seen it cause more problems. Am I missing anything else?
