Leash electronics dual 70 amp relay . Thermostatic switch to trigger it , a switch , ecu whichever you prefer and doneSuggestions for contour dual fan controller?
Pig tails for the fans . Smaller wire for your relay trigger 12v and ground . You’re good to goAll I really want is for them to kick on at say 160 or 170 and kick off when it gets 10degrees colder. I don’t care about two speed or ac over ride. So all I would need is that leash dual 70 amp relay, some 10 gauge wire, and a thermo switch? @TOOLOW91
What type of switch are you using? I really like that leash relay board but was unsure about how to control it independent of the ECU.Leash electronics dual 70 amp relay . Thermostatic switch to trigger it , a switch , ecu whichever you prefer and done
You could use a gm temp sensor , flexalite fan controller . Whatever you prefer . I ran a flexalite fan controller as the switch before I I had a stand alone ecu . Now my ecu triggers itWhat type of switch are you using? I really like that leash relay board but was unsure about how to control it independent of the ECU.
^^^This!Flex A Lite 33165
I think I'm going with the Autocool 85. It's a pwm controller and is far better designed than most of these other controllers. Check it out. I'm sure you'll be impressed too. Also, the one guy that builds these things is super cool and will answer any questions you have over the phone. Very small business but really good product.^^^This!
I used this controller for my contour fans without issue for years. Don’t over think it.
I knew going in to expect a wait and not to expect direct attention from the maker. I thought the instructions were written well enough and I needed nothing further. The controller has worked perfectly for me.The DCC works well and it is what I am currently using. Lead times are long and customer service is nothing short of terrible. This thread actually made me look back at my emails with Brian, the owner, and I was appalled.
