- Mar 1, 2008
- 7
- 0
- 0
If anyone has ever done a 3.8 V6 to a 4.6 V8 swap, I would really like to know everything that I need.
Thanks,
Jeff
Thanks,
Jeff
it would be easier just to sell your car and buy a GT. possibly cheaper too.
I've done it on mine.
There are quite a few good threads around the web about it. You might want to check 3.8mustang.com as well.
Here's a quick summary.
You'll need OFF a V8 mustang:
- engine
- transmission and mounts
- driveshaft
- CCRM and Computer
- engine-to-CCRM wiring
- CCRM and Engine to Computer wiring
- rear end
- gauge cluster
- v8 brake system
- exhaust (manifolds, h pipe and mufflers)
The swap itself is pretty straight foward, all the mounts and k member pieces of your V6 wil work with the V8. I'd recommend replacing as much of the stock stuff (bushings, mounts and such) while doing the swap, just because its easy to do so at that stage.
Once the swap is complete, you'll need to tow your car to a ford dealer so that they can reprogram the PATS system. Basically, your V6 key's and ignition must be programmed to work with the gauge cluster and computer of the v8. You might have a hard time finding a dealer to do this because I'm quite positive it's illegal, so if you have connections, it helps.
Good luck! The swap is A LOT easier than it sounds, so dont lose hope when people say sell your v6 and buy a v8. It's WAY cheaper to swap.
Don't take this as a guide, as I may be missing a few items, I did my swap over a year and half ago.
Correct, my car is not a true GT, it's a swapped ex-V6.
And incorrect when you guys say it'll be cheaper to sell and buy a GT.
I ended up spending a total of $500 to upgrade from V6 to GT (with ALL gt parts).
And no, you DONT need the front GT suspension, the V6 one is identical. But I upgraded my stuff anyways.
Thanks,
Jeff
