what year model trucks etc. should I be looking for in the salvage yards to make sure I get a roller block ......
bluevenom867 said:Late model trucks and (you'll never find one with the motor,but) first gen Lighting's.
dbdragracing said:Aren't the 351W roller blocks the weakest? If not, what are the stronger 351W blocks? Thanks.
my289eatsrice said:The strongest 351w block is the 69-70, but any 351w block is still substanitally stronger than a 302/5.0 block. All 1994 to 1997 f-series trucks had roller blocks, I'm not sure about the e-series and bronco's tho. Anyways it's easy to convert to a roller block.
id almost guarantee its a roller. id get it. i just got one from a 96 with 140000 for 500. if you want to check if its a roller, take off the passenger side valve pan cover and take off one of the rockers and pull out the pushrod and with a small light lokk down in there to see if the is a lifter guide. if there is its a roller. i went with roller because it was just going to be easier. cam selection for instance.2002BLGT said:the engine I found is actually a Bronco engine out of a 95 model ....its running and the salvage yard is asking $550 for it with 89K miles on it ....
